Light knocking from under car - drive backlash / play.
lugars4
Post by lugars4 » Mon Feb 21, 2011 9:02 pm
Recently i noticed at very low speed, such as when the engine speed at tickover almost exactly matches the wheel speed for 1st gear, i hear a light knocing fron under the centre of the car. Like there is some backlash in the drive.
Most noticable when reversing and lifting on / off the clutch, its a light audiable knock or clunk. Sounds like it comes from below the gear stick area. possibly slightly to the drivers side.
I could almost swear that it only started recently, but i may just be noticing it more now that i am aware of it.
Is this normal? am i being too fussy? or has anyone experienced anything similar. Its not noticably loud, but i can heat enough to question it.
Appreciate any input.
Cheers.
Ice_Coffee
RE: Light knocking from under car - drive backlash / play.
Post by Ice_Coffee » Mon Feb 21, 2011 10:03 pm
Do you have any idea if your car used to have a miltek ?? I only ask because a poorly refitted exhaust would cause your symptoms.
lugars4
Post by lugars4 » Mon Feb 21, 2011 11:27 pm
Not that i am aware of no. . . .
lugars4
Re: Light knocking from under car - drive backlash / play.
Post by lugars4 » Tue Mar 15, 2011 10:30 pm
Turned out to be the propshaft had excess play, Replaced under Warranty,
06 - B7 RS4 Saloon - Milltek Non-Res Valved. BMC Filter.
lugars4
Post by lugars4 » Sat Jun 01, 2024 11:37 pm
And 13 years / 33k miles later, i am hearin a similar sound again.
This time i need to inspect myself..... Quite loud when making low speed manouvers rocking on/off the drive train slack.
coffey555
Post by coffey555 » Mon Jun 03, 2024 3:51 pm
Audi don't sell the centre bearing on its own, it can only be purchased with the complete prop-shaft assembly..... which is certainly not cheap!
When we did my underside restoration, we ordered up a 034 Motorsport bearing and refurbished the existing prop.
Runs perfectly.
https://www.034motorsport.com/driveshaf ... 7-rs4.html
https://www.awesomegti.com/034motorspor ... gs-rs4-b7/
Misano Red RS4 B7 Avant
lugars4
Post by lugars4 » Mon Jun 03, 2024 9:00 pm
Great thanks for sharing.
Will inspect mine shortly.
Users browsing this forum: No registered users and 130 guests
