Couldnt see a thread of shared results.
Interested in the torque profiles of different cars / tuner maps.
For reference, this is the standard torque curve from the brochure.
This is a bit of data i found on how someone had tested the flap openings, throttle opening v.s RPM etc. Interesting plot.
This is mine pre-cleaning. Notice the torque falling off from 4000rpm when it should start picking up.
I also had a stuck air box flap on this test.
Post your Rolling Road Results Here
06 - B7 RS4 Saloon - Milltek Non-Res Valved. BMC Filter.
Re: Post your Rolling Road Results Here
I can't seem to copy a pdf to add here.
Sprint Blue B7 RS4 Saloon with MRC tweakery.
Should allow you on the attachment section when making a new post. Make sure you are in full / advanced post mode.
Look forward to seeing some results.
Here’s mine. Before and after carbon clean, decat downpipes and Stage 2 tune at MRC.
The only 'add image' icon I can see seems designed for weblinks only. Tried dragging and dropping and using the attachment tab at the bottom - doesn't seem to work for me.
I converted it to Jpeg for you.
Many thanks!
Wheels refurnished last year and some small bits of corrosion being attended to this month - still intend to get the leather tidied up a little (it's in pretty good nick, but the car's a keeper) and have an aftermarket exhaust added.
