seized pinch bolts on upright+track rod end
rs user
Post by rs user » Wed Jul 26, 2017 5:47 pm
replacing my front coilovers today-found my track rod end pinch bolts and upper control arm pinch bolts seized-both sides-they dont look bad but are solid
managed to change the coilovers in any case[bit of messing around] but eventually will have to deal with the stick bolts
whats the best and least destructive method of removing these-drill? laughably last weekend was spent drilling out completely seized anti rattle pins on the brembos...these didnt look bad either but were fused into the calipers
Harris.
Re: seized pinch bolts on upright+track rod end
Post by Harris. » Wed Jul 26, 2017 9:38 pm
Soak in wd40 for a few days . Mine were the same but I kept turning it then it freed itself . The top arm pinch bolt took an hour of turning
Do not heat it up it will crack it
Pistolpete2543
Post by Pistolpete2543 » Wed Jul 26, 2017 9:51 pm
Its a common problem, quite a few YouTube videos with "how to" guides.
rs user
Post by rs user » Wed Jul 26, 2017 10:26 pm
will soak it some more...then have a wee go with an air punch
i did give them a quick squirt of wd40 last week
bit of a pita fitting coilovers without undoing either..
Users browsing this forum: No registered users and 402 guests
