Clutch issue
boombastik
Re: Clutch issue
Post by boombastik » Tue Dec 13, 2016 2:08 pm
irn_bru_ce wrote:So the original audi master cylinder is made of plastic? Outrageous
the slave cylinder is the master is under the dash and its plastic
RS4 B7 Saloon Milltek Cat back, CAF with piper cross panel, Wrapped optics black, Satin black wheels, TRUPS LED front DRL's & sides, goodridge braided hoses, H&R 10/15mm spares front/rear
Bilstien B16 coilovers with H&R anti roll bars
MRC stage 2 deflapped, precat gutted 439ps 481nm torque
1/4 mile time 12.884sec
My clutch replacement write up can be found here viewtopic.php?f=35&t=116929&start=15
boombastik
Re: Clutch issue
Post by boombastik » Thu Dec 22, 2016 4:45 pm
Update on the car
Up at the garage for 730 this morning got it on the lift so I have replaced the clutch bearing slave cylinder clutch lever & replaced the rubber pipe for a braided pipe.
All back together bleed the system and everything is working fine
Having inspected all the parts I replaced I can't find any faults with any of them...
Any way I now have gearbox removal and replacement to a fine art now haha.
DavidRS4
Re: Clutch issue
Post by DavidRS4 » Thu Dec 22, 2016 7:17 pm
Good to hear.
jonson66
Re: Clutch issue
Post by jonson66 » Thu Dec 22, 2016 9:27 pm
You can come and do mine then when it needs doing lol
Seattle-squash
Re: Clutch issue
Post by Seattle-squash » Fri Dec 23, 2016 2:20 am
Nicely done! :) did the USP line work for the right hand drive?
boombastik
Re: Clutch issue
Post by boombastik » Fri Dec 23, 2016 8:27 am
Seattle-squash wrote:Nicely done! :) did the USP line work for the right hand drive?
Unfortunately not it was about 8" too short. So getting sent back today.
Seattle-squash
Re: Clutch issue
Post by Seattle-squash » Fri Dec 23, 2016 9:58 am
You got one fabricated instead or you picked up a right hand drive specific one?
markshepps
Re: Clutch issue
Post by markshepps » Fri Dec 23, 2016 10:00 am
Arse... I've just had one of these delivered. I thought I'd seen others on the forum using this setup?
boombastik
Re: Clutch issue
Post by boombastik » Fri Dec 23, 2016 10:19 am
You will be able to use it but you will need a braided pipe made to suit and long enough to attach from the slave to the metal pipe just coming down from the firewall I just didn't have time to get one made
markshepps
Re: Clutch issue
Post by markshepps » Fri Dec 23, 2016 12:26 pm
Arse... I've just had one of these delivered. I thought I'd seen others on the forum using this setup?[/quote]
You will be able to use it but you will need a braided pipe made to suit and long enough to attach from the slave to the metal pipe just coming down from the firewall I just didn't have time to get one made[/quote]
Just ordered Robnic's braided pipe instead... Too much faffing about already... My flywheel has been stuck in customs for over a week and no sign of it getting to Parcel Force anytime soon... T'is the season I guess! Rob's team were great at getting the pipe sorted... Friday before Christmas... Had it made & shipped before lunch time!
Mr Footlong
Re: Clutch issue
Post by Mr Footlong » Sat Jan 07, 2017 1:43 pm
mikep99 wrote:Mines in at the moment for a gearbox rebuild / clutch and uprated pipe. Can't wait to get it back.
3rd gear synchro the main reason it's being done....
If you don't mind saying, can you go in to more detail about what exactly you had rebuilt/replaced on box, how much it cost and how it feels now? Thanks.
Current:
Gone:
mikep99
Re: Clutch issue
Post by mikep99 » Sat Jan 07, 2017 2:33 pm
The 3rd gear synchro failed leading to crunching going into 3rd.
I've had the gearbox rebuilt - the only thing they found that needed replacing was the 3rd gear synchro, everything else was ok.
When it was put back in the car I had the clutch, master cylinder and uprated return pipe fitted.
About £1600 all in and it feels fine now.
Had it done just before Christmas and done about 600 miles.
HTH
Mike
Mr Footlong
Re: Clutch issue
Post by Mr Footlong » Sat Jan 07, 2017 5:15 pm
Not bad, was that with an OE clutch or LUK? Boggo master cylinder and Robnic clutch i assume from your earlier post. Who dropped/rebuilt/refitted the box please? Thanks.
Current:
Gone:
mikep99
Re: Clutch issue
Post by mikep99 » Sat Jan 07, 2017 5:41 pm
yep, luk clutch, standard master & Robnic pipe.
I used http://www.qrsport.com
They use a gearbox specialist once the box has been dropped etc...
ta
Mike
Mr Footlong
Re: Clutch issue
Post by Mr Footlong » Sun Jan 08, 2017 7:46 am
Thanks, useful info to have on here for others.
Current:
Gone:
Users browsing this forum: No registered users and 355 guests
