Led rear lights
MarkV8
Led rear lights
Post by MarkV8 » Mon Aug 22, 2016 7:04 pm
Can anyone recommend led rear lights that won't throw up a can bus warning cheers :beerchug:
Rick_RS4
Re: Led rear lights
Post by Rick_RS4 » Mon Aug 22, 2016 7:57 pm
dont buy cheap
dectane are good, theres an ebay Shop too
weekenny
Re: Led rear lights
Post by weekenny » Mon Aug 22, 2016 7:59 pm
I have dectane ones they throw a fog light code.
MarkV8
Re: Led rear lights
Post by MarkV8 » Mon Aug 22, 2016 9:34 pm
That's wot I want to avoid the dreaded codes, so I'm trying to find a plug and play set.
Re: Led rear lights
Post by MikeFish » Tue Aug 23, 2016 7:59 am
I've had 2 sets of rear LEDs and both threw up the odd error when starting the car in the dark with auto lights on but after a couple of months the errors stopped. Any time the error did appear a quick turn off and on would fix it. Or not leave the lights on auto. If you don't have auto lights then you will probably never see the error as it only came on when starting the car from cold with the lights in ie low battery level and trying to check lights at the same time.
MarkV8
Re: Led rear lights
Post by MarkV8 » Sun Aug 28, 2016 10:05 pm
Cheers mike fish I do unfortunately have auto lights but if I use them manually they should be ok is that wot u mean, tell me I have 2 switches one is for drl and thair is another by the side of it do u no wot thiss is for is it adaptive headlights?
Starry
Re: Led rear lights
Post by Starry » Sun Aug 28, 2016 10:07 pm
MarkV8 wrote:Cheers mike fish I do unfortunately have auto lights but if I use them manually they should be ok is that wot u mean, tell me I have 2 switches one is for drl and thair is another by the side of it do u no wot thiss is for is it adaptive headlights?
i think thats your dash light dimmer.
2006 RS4
Phantom black
MarkV8
Re: Led rear lights
Post by MarkV8 » Sun Aug 28, 2016 10:14 pm
Hahaha it is to I'm blinder than 3 bats together cheers bud :biggrin3:
Re: Led rear lights
Post by MikeFish » Mon Aug 29, 2016 7:36 pm
To the left of my DRL switch is the coming home lights switch (turns fog lights on when you unlock the car at night, or when you turn car off and get out at night).
MarkV8
Re: Led rear lights
Post by MarkV8 » Mon Aug 29, 2016 7:59 pm
MikeFish wrote:To the left of my DRL switch is the coming home lights switch (turns fog lights on when you unlock the car at night, or when you turn car off and get out at night).
I'm with u my s4 used to do that wen it was dusk glad to no it's on the rs4 cheers fella
Starry
Re: Led rear lights
Post by Starry » Mon Aug 29, 2016 8:08 pm
ah, i was guessing as I've not been out in the dark in mine yet, wheres the dash light adjuster then?
2006 RS4
Phantom black
Surrey Sam
Re: Led rear lights
Post by Surrey Sam » Mon Aug 29, 2016 11:15 pm
+ & - buttons below the rev counter :wink:
irishmike
Re: Led rear lights
Post by irishmike » Tue Aug 30, 2016 6:31 pm
I didn't know it could be adjusted, thought it just worked in conjunction with the lights...
Starry
Re: Led rear lights
Post by Starry » Tue Aug 30, 2016 8:01 pm
Every days a school day... thanks Sam
2006 RS4
Phantom black
Users browsing this forum: Google [Bot] and 209 guests
