MRC working their magic...
Re: MRC working their magic...
Post by MikeFish » Sat Mar 26, 2016 11:38 am
They don't often mention the vac leak.
Yeah 390 is low for a carbon clean and standard car. Mine was 390 before remap and no clean.
And 325 is way too low for carbon.
Scub37
Post by Scub37 » Sat Mar 26, 2016 12:41 pm
This is the dyno I got when they tried it in 5th gear
Scub37
Post by Scub37 » Sat Mar 26, 2016 12:42 pm
JCviggen
Post by JCviggen » Sat Mar 26, 2016 5:06 pm
Scub37 wrote:This is the dyno I got when they tried it in 5th gear
Did that outfit do the remap as well? As it's on a different dyno from what we usually get numbers from (MRC) it's hard to compare. The dips in your graph are probably timing pull due to bad cooling and a longer/harder run than usual. Looks good otherwise, but not easy to compare to other people's results.
Do a 3000-8000 test in 3rd on level ground and see what you get, tells you a lot more than a dyno plot.
B7 RS4 saloon Misano red, comfy seats, JHM tune & JHM full exhaust with cats and resonators - gone.
C5 RS6 Avant Daytona/Cognac - gone.
981 Cayman GTS Gray/Orange.
My youtube
Post by MikeFish » Sat Mar 26, 2016 6:29 pm
Also hard to compare results as it wasn't cleaned by MRC or mapped by them. I thuoght you had the work done there hence why I said it was a low as I know how good their clean is and what the results of their remaps are. Might be nothing wrong with your car, may just be a case of not as good a clean as MRC do or a bad map.
I was also surprised that you were asking here if there was a problem as MRC would have told you exactly what the problem is. Moral of the story is go to MRC as they know what they are doing. You wouldn't have left there without an explanation of exactly what was wrong.
Spectre
Post by Spectre » Thu Mar 31, 2016 12:45 pm
MRC results look like this (de-coke, Stage 2 map and de-flap).
Mak.
2013 Guards Red 991 Carrera - VERY MUCH Arrived.
2013 Ibis White RS4 B8 - Gone :)
2007 Phantom Black Avant RS4 B7 - Gone :(
FaisalJ
Post by FaisalJ » Thu Mar 31, 2016 1:06 pm
Wow, I bet +60PS feels a bit different! That's more than my first car!
2007 RS4 B7 Avant
toyneg
Post by toyneg » Thu Mar 31, 2016 2:33 pm
this is mine
Users browsing this forum: Bing [Bot], Google [Bot] and 36 guests
