Afternoon gents,
My rear heated screen doesn't work, it hasn't since I bought the car two months ago! Now I've done the simple thing an changed the fuse with no joy! Are there any common faults or any suggestions to why it isn't working?
Thanks in advance,
Matt
Rear heated screen problem
- PetrolDave
Re: Rear heated screen problem
The heated rear screen is also used as one of the aerials for the radio.BiebaRS4 wrote:My rear heated screen doesn't work, it hasn't since I bought the car two months ago! Now I've done the simple thing an changed the fuse with no joy! Are there any common faults or any suggestions to why it isn't working?
To avoid interference on the radio there is a filter in series with the feed to the heated rear screen that separates the power from the aerial signal, I suspect that may be your problem - it's a not uncommon fault on Audis.
RSCosworth
- 1st Gear
Where is this filter located?? My heated screen doesn't work either plus my radio reception is terrible so I highly suspect this could be my problem too, what do you think??PetrolDave wrote:The heated rear screen is also used as one of the aerials for the radio.BiebaRS4 wrote:My rear heated screen doesn't work, it hasn't since I bought the car two months ago! Now I've done the simple thing an changed the fuse with no joy! Are there any common faults or any suggestions to why it isn't working?
Mugello Blue B7 RS4 Avant, Black Optics, Buckets, FBSW, Carbon Inlays, Completely Standard
Previously owned:-
Nissan Sunny GTi-R
Renault Clio Williams
Ford Escort RS Cosworth
Renault Clio V6
Mitsubishi Lancer Evo 7
BMW M3 E46
Previously owned:-
Nissan Sunny GTi-R
Renault Clio V6
BMW M3 E46
- PetrolDave
Sounds like the likely culprit.RSCosworth wrote:Where is this filter located?? My heated screen doesn't work either plus my radio reception is terrible so I highly suspect this could be my problem too, what do you think??
IIRC it's behind the trim above the rear window on the saloon, and behind the rear side trim (can't remember if it's LHS or RHS) on the Avant.
RSCosworth
- 1st Gear
Nice one cheers buddy, will check it outPetrolDave wrote: Sounds like the likely culprit.
Previously owned:-
Nissan Sunny GTi-R
Renault Clio V6
BMW M3 E46
Previously owned:-
Nissan Sunny GTi-R
Renault Clio V6
BMW M3 E46
Users browsing this forum: Google [Bot], Zyox and 356 guests
