8mm h&r spacers vibrations
CellDamage
Re: 8mm h&r spacers vibrations
Post by CellDamage » Tue Mar 11, 2014 9:55 pm
Fair enough, I had a look earlier and tried mounting one of the 8s. No wonder they cause wheel vibration, there's literally nothing for the wheel to sit on, not to mention the increase in radial loading in the bolts can't be good for them?
Cheers for the part number.
Mr Footlong
Post by Mr Footlong » Tue Mar 11, 2014 11:05 pm
Pretty sure I have seen this discussed before but.....
Any arch rubbing front/rear with the 8/10 kits?
Other than mild aesthetics, any other reason for the spacers?
Thanks.
Current:
Gone:
Rick_RS4
Post by Rick_RS4 » Wed Mar 12, 2014 2:55 am
CellDamage wrote:Fair enough, I had a look earlier and tried mounting one of the 8s. No wonder they cause wheel vibration, there's literally nothing for the wheel to sit on, not to mention the increase in radial loading in the bolts can't be good for them?
yes exactly this
Mr Footlong wrote:Pretty sure I have seen this discussed before but.....
Thanks.
no rubbing and i was low, Increasing track width (not wheelbase) = REDUCING the total amount of lateral (side/side) weight transfer. Negative effects include increased stress on wheel bearings
CellDamage
Post by CellDamage » Wed Mar 12, 2014 12:01 pm
Anyone want to buy a set of 8mm non hub-centrics for the front? They don't cause wheel vibration, promise :bigblink:
Virdee Autos
Trader (Expired)
Post by Virdee Autos » Wed Mar 12, 2014 9:42 pm
As always we have the correct bits all in stock
Fit and forget!
Virdee Autos ~ 07950-526592
Daytona RS
Post by Daytona RS » Thu Mar 13, 2014 5:52 pm
yes exactly this
Thanks.
Agreed
Mr Footlong
Post by Mr Footlong » Fri Mar 28, 2014 5:55 pm
Got the kit from Virdee. Fitted today. Not sure what all the fuss is about after fitting them tbh and not cheap, but you can't fault the quality of the spacers, absolutely DEAD on machining :)
Current:
Gone:
GAZ-MAN
Post by GAZ-MAN » Mon Mar 31, 2014 6:18 pm
Have exact same problem bought coilovers then spacers non hubmetric and the vibrating is driving me insane, so ive just text virdee to get full new set ordered up :jump_clap:
Users browsing this forum: No registered users and 370 guests
