Inlet manifold flaps removal question
Eashan
Post by Eashan » Thu Aug 02, 2012 6:20 pm
I have removed the flaps from the inlet manifold. I need a bit of help. Can you remove the flaps inside the engine too or do these need to stay in? I'm having a remap so any codes that come up wouldn't be a problem.
B7 RS4
Black Optics
20" A5 wheels
Milltek-non res-no valves
ROY
Re: Inlet manifold flaps removal question
Post by ROY » Thu Aug 02, 2012 6:23 pm
I'm doin mine on Monday and will be removing the tumble flaps
How've you gone on removing the manifold flaps ?
Did you remove the core plugs and where did you get them from ?
Pics pics pics pics please :thumbs:
Gone but not forgotten boohoo !!!
RS4 Sprint Blue Avant on Dyno after Carbon Clean http://youtu.be/7lsBbmmaDQc
Eashan
Post by Eashan » Thu Aug 02, 2012 7:33 pm
I have had it done at a local garage and it's still there for a decoke. I will take some pics when I get it back. They have taken out the core plugs and welded the holes somehow. I will get more info tomorrow. Some of the core plugs were very loose so I rather not have them at all as I don't need them now. What do the tumble flaps do? Will it make a difference removing them? Are you doing a decoke?
B7 RS4
Black Optics
20" A5 wheels
ROY
Post by ROY » Thu Aug 02, 2012 8:57 pm
Yep doing a decoke on Monday - got everything ready including core plugs.
How did they manage to weld the manifold its aluminium ?
I don't fancy the new plugs coming out either but not sure if i would weld the holes :shock:
Eashan
Post by Eashan » Sat Aug 04, 2012 10:52 am
Yes they have welded the holes. Why is aluminium a problem to weld? I wil post pics later. It's all done now jus needs a map tweak. Who is going to map yours? I will post pics later.
B7 RS4
Black Optics
20" A5 wheels
adsgreen
Post by adsgreen » Sat Aug 04, 2012 11:27 am
Aluminium is possible to mug weld - plenty of track/race fuel tanks are aluminium welded.
However I wouldn't weld a point that is so likely to suffer heat stress.
There nothing fundamentally wrong with core plugs - they've been used for years all over the place.
As long as they are the right size and material. The holes *should* be slightly tapered in doing they do work loose they should have the tendancy to pop out than in.
(my dad use a wooden dowel as a temp repair job once)
Ones with the top hat are probably as far as you'd want to go.
Eashan
Post by Eashan » Tue Aug 07, 2012 12:03 pm
Heres some pics
B7 RS4
Black Optics
20" A5 wheels
ROY
Post by ROY » Tue Aug 07, 2012 2:49 pm
Nice job Eashan :thumbs: :thumbs: :thumbs:
Dave_M
Post by Dave_M » Tue Aug 07, 2012 4:28 pm
That does look neat and completely removes any risk of the engine ingesting a core plug. I'd be worried however that the heat from welding could distort the manifold's mounting face, making it impossible to get an airtight seal.
2007 B7 RS4 Daytona Avant (the daily driver)
Other current toys: 210bhp Caterham 7 (track toy), 1994 380bhp Escort Cosworth Monte (awaiting engine rebuild), MX5 1.8 Sport (strictly my wife's!)
Gone: Nissan 350z roadster, 205 GTI Mi16, Classic Impreza 2000 Turbo, Nissan Sunny GTiR, Corrado G60, 205 GTI 1.9, Rover Metro Gta (don't ask!), Escort 1.6i cabbie, MG Metro (first car)
Users browsing this forum: No registered users and 111 guests
