New cylinder block - 2 weeks left on warranty!!!
Took the RS4 into the garage as I had a engine warning light come on. Diagnostics confirmed it was a failed solenoid for the secondary air. Took the car into Worthing Audi and had a phone call asking whether the car was using a lot of oil!!! When ask why, I was advised that while changing the solenoid they had found a lot of burnt oil under the car. Further diagnostics found that the engine was 'fluttering' at 1700rpm a known sign that the there may be a problem with the cylinders. Cylinder head was removed and 3 of the bores had started to score and polish. 3 weeks later and I have a new cyclinder block and remapped engine. Apparantly to avoid this problem the engine has to run 2-3 degrees hotter. All work done under warranty with only 2 weeks left!!!!!! Car had done 38,000 miles. All credit to Worthing Audi, the car had only gone in for a cheap solenoid replacement and ended up as a £9k job!!! If this hadn't been picked up I could have had a nasty bill in 6 months time.
- PetrolDave
Re: New cylinder block - 2 weeks left on warranty!!!
Hmmm.... not sure I see how that would make a difference?jimbosale wrote:Apparantly to avoid this problem the engine has to run 2-3 degrees hotter.
Did they give you any proof of this statement?
Not seen anyone else post this issue either on forums here or in the US.
Jimbo, I'm currently having probs with my motor...thro' many discussions with my dealer, it was mentioned that I'm running ECU version 0080. He stated that version 0090 was for motors that needed to run at higher temperatures due to lots of town driving etc...? (still unsure what he really meant)Apparantly to avoid this problem the engine has to run 2-3 degrees hotter.
Is your remapp using version 0090.
I'm sure the flutter Audi is referring to is piston ring flutter. It usually happens at high RPMs under low engine loads. In these situations, there isn't enough cylinder pressure to keep the rings square to the bore. This results in more blow-by and higher crankcase pressure. This phenomena shouldn't have any affect on the mass-air sensor readings. I believe high RPM flutter is normal. If the ring flutter happens at lower RPMs, bore wear will be accelerated - which is apparently what happened to jimbo's engine. Why exactly? Hard to say...SR71 wrote: Can you expand on the symptoms of a "fluttering" engine?
Are you talking about a "fluttering" mass flow rate?
rsowneraudi
rsowneraudi
Users browsing this forum: Google Adsense [Bot] and 322 guests
