Can anyone tell me if the above size is okay for all four corners or are the ones at the back different? I guess they should be the same, only these are slightly over sized to fill the arches so a bit unsure what I should be ordering.
Cheers alex
IIRC there's already some pics on here.RS44ME wrote:Further, could anyone show us some pics of what the B7 RS4 looks like with 275/30R19s ?
Also, how much does this put the speedometer out by ?
My findings exactly...PetrolDave wrote:FWIW my previous S4s have had much more accurate spedos which over-read by only 2%.
All values compared to a GPS speedo.
Not if you want it to alarm at the same difference from your new "normal" pressures.P_G wrote:Recoded? Do you just not reset your TPMS vis DIS ASAP RSVP?
