Damaged Alloy B7 RS4
simple1
Post by simple1 » Sun Oct 28, 2007 8:25 am
..... you need to go back and kick the tyre fitters arse, the valve on the wheel is also the sender unit for the low pressure warning system and the unit is a tad more than a standard valve to buy.
charlesraz
Post by charlesraz » Sun Oct 28, 2007 10:17 am
i 2 have damaged a front. went to my audi dealer for advice on repair. they where honest saying that they where unable to match the n factory finish. while waiting i hada close look at the second hand cars for sale. i am sure that they had been repaired. the depth in colour /gloss finish had been lost and on some there was not consistency in shape. if ur buying second hand- check. there is also a big difference in the tyre walls between pirelli,continental and michelen, with pirelli giving the most tyre wall shoulder protection. i hav decided to buy new and use the advice posted to repair the damaged wheel
jacko
Post by jacko » Sun Oct 28, 2007 10:27 am
It must be the season for kerbing!!
I've just taken my girlfriend to the hospital and driven through an impossibly narrow gap entering a multi storey and done my off side alloy, it's only a scrape but a scrapes as bad as a gouge isn't it?! I love the car so much that I'm secretly blaming my bird for being ill!
You can be as careful as you want but you can't legislate for stupidly narrow gaps.
GUTTED!
itaggart
Post by itaggart » Mon Oct 29, 2007 10:57 am
I still have the damaged wheel, can I remove & refit the existing sender/valve to the new wheel?
paulslacey
Post by paulslacey » Mon Oct 29, 2007 3:47 pm
As far as i rmember the silver valve is also the sensor for the pressure system, so it needs to go back.
2007 R8 IBIS White with all the toys
2004 Dodge Viper Mamba #86 of 200
1998 Dodge Viper GTS/R 1 of 100 #52 The Justin Bell car
2007 Harley Davidson 'Street Glide' 1 of 200 Harley Custom Paint
'Its the car, chicks dig the car'
RS4Molar
Post by RS4Molar » Thu Nov 01, 2007 2:08 pm
My RS4 arrived at the dealer with the front offside valve unit damaged and a rubber placed. Still waiting on the OEM valve unit to arrive ? Meanwhile had to switch off TPMS as it would pop up all too often.
Let you know how it goes.
2007 Phantom Black DnA tuned (UK)stage 3 B7 RS4 saloon, hotchkis arb's, H&R springs, goodridge lines, ferodo DS 2500 pads, GMG cat back exhaust system, BMC panel filter.
2005 Grey B5 A4 2.0 TFSI sedan
2000 WRC WRX turbo-210/285 (kw/bhp) atw
P_G
Post by P_G » Thu Nov 01, 2007 5:01 pm
TPMS isn't standard though is it? How do you tell if your RS has TPMS?
pippyrips
Post by pippyrips » Thu Nov 01, 2007 9:41 pm
Don't quote me but i think it is - go in to your menu and you should find it.
P_G
Post by P_G » Fri Nov 02, 2007 9:47 am
The DIS menu? I've got the normal mpg and mileage sections and lap time but nothing else IIRC.
Adam
Post by Adam » Fri Nov 02, 2007 11:55 am
It is std and you can set it in the DIS - RTFM as we say!
Users browsing this forum: Google Adsense [Bot] and 259 guests
