Engine air leak
1.8 I4 20v turbo - 207bhp
1.8 I4 20v turbo - 222bhp
S3MXLA
Engine air leak
Post by S3MXLA » Wed Sep 13, 2006 5:45 pm
Hi all,
Can anyone shed some light on the strange behaviour of my engine.
(Its a 2000, 210bhp) The car mostly seems very flat (no turbo kick) and occasionally will splitter badly at 4-5000rpm under load. Or it may kick in with a very impreesive surge of power at say 5000rpm.
You never quite know what to expect. VAG diag has detected 2nd air leak, mechanic recommends replacing to pipes at front of engine?!
Will this have any effect? Has any one suffered this?
Mark
lenrs6
Post by lenrs6 » Sat Sep 23, 2006 6:47 pm
mark
sound familiar. i had a 99 S3 for 5 years and after 20,000 miles, noticed a very obvious 'flat spot' of power delivery around 4000rpm. likely to be the same thing. as i recall, it was diagnosed as a fuel injection/pump issue. was fixed under warranty so no idea of cost, but sorted the problem, never to return...
hope this helps
len
lenrs6
mark
hope this helps
len
BlackS3
Post by BlackS3 » Sat Oct 21, 2006 11:11 am
Air leaks can be common. Replacing pipes is an obvious easy starting point.
Return to “S3 (Typ 8L) 1999-2003”
