What are the OEM brake pads
Sorry if this is a stupid question, but couldn't find the answer with the search facility.
Don't want to pay Audi prices for pads, but want to stay with the stock pads. Are they pagids like the RS6?
Cheers.
Cheers.
I think they are pagids. Would make sense cause the s3 were and rs6, plus i think the rs4's are pagids too.
dunc
dunc
Thanks guys. Is there just one model of Pagid?
There must be a lot of good alternatives to the OEM discs, from within the Audi models with same spec brakes as well as aftermarket?
Clive
Just ordered rear Pagid discs through Euro car parts over Christmas whilst I was home to sign for them. 300mm for the rears alone, they are heavy! I gather Pagid are OE.marv wrote:Are the OEM discs available cheaper elsewhere too? Are they made by someone like pagid?
Pads are more complicated, as there appear to be differences between B6 and 7 calliper, and there also appear to be several OE suppliers. I read that Lucas were an OE supplier, and tracked down rears for a very good price, hence bought some. They arrived in a Mintex box, but a quick research shows Lucas and Mintex are now one and the same.
Ideally wanted a set of discs and pads as I think my discs will be getting down towards borderline come mot in June. Don't want to get stuck and have to pay Audi prices - won't be back from Le Mans before my mot expires, so it's not like I can leave it parked up for a few days waiting for parts.
Ian
- BlingBling
The B6 & B7 have different rear suspension and brakes. That why only the B7 RS4 fronts fit B6's.Pads are more complicated, as there appear to be differences between B6 and 7 calliper,
The only viable option from within the Audi range is the B7 RS4 set up.´The S4 brakes are fairly big, 345mm, and generally not too shabby.There must be a lot of good alternatives to the OEM discs, from within the Audi models with same spec brakes as well as aftermarket
WRT aftermarkets set ups. There are not many options unless you go big brake, which is an over kill unless you track frequently. The Phaeton and Cayenne set up can be used with a few minor changes.
The best way of improving the standard set up is to fit braided hoses and use DOT5 brake fluid.
