RS4 anti-roll bars - worth it on an S4?
xyber
Re: RS4 anti-roll bars - worth it on an S4?
Post by xyber » Fri Apr 29, 2011 12:56 pm
Hotchkis bar is greased. The mounts even have grease nipples built into them
•••MyProtein Discount code MP486494•••
cobraBLACK
Post by cobraBLACK » Fri Apr 29, 2011 1:08 pm
Also, thread locker in the clamp bolts is a good idea.
I bought some specially but the garage used their own.
I remember trying to do a quick manoeuvre round a 90 degree bend like I was in an Impreza before I got the RARB fitted. It was terrible - although the S4 feels tight at lower speeds, it felt like a capsizing barge (it was just after overtaking an M5 so I must have looked a dick).
I tested out the cornering with the RARB properly for the first time the other week by navigating 180 through a roundabout at speed - I think it went through just as quick as my Impreza but with less body roll. Impressive.
Audi S4 Avant (B6, 2004) in Goodwood Green.
Sharkfan
Post by Sharkfan » Thu May 12, 2011 7:43 pm
Hi,
Has anyone got all the part numbers for upgrading the bar - my car is an 04 S4 Cab?
Cheers,
goose
Post by goose » Tue May 17, 2011 8:43 am
biyitch wrote:Correct me if I'm wrong, but don't the B7 S4s use the same (thickness) RARB as the RS4s (also B7)?
I can confirm that the B7 S4's have the same 22mm RARB as the B7 RS4's.. as i found out when my local VAG specialist spent half hour getting the old bar off, put it on the floor next to the new one and noticed they are identical :shock:
Unless of course the previous owner already did this mod and didn't mention it :sekret:
goose
Current:
'08 Carbon Black BMW X5 3.0sd M Sport|Full white interior bulb kit|White LED Halos|De-badged
'72 Sunburst Yellow VW Karmann Ghia Coupe|1641cc|Engle 110 Cam|Weber 34 Carb|dropped spindles|Porsche 911 interior
Past:
'06 Phantom Black Pearl Audi B7 S4 - Milltek non res|BMC Panel|034 25mm RARB|SuperPro poly bushes|Apikol poly Snub|H&R Springs|H&R 10mm rear spacers|LCR Splitter|R8 caps|JCap|RS4 Pedals|EBC D/G disks & yellow pads|HEL brake lines|White sides/DRLs|De-tango'd
Post by Ian_C » Tue May 17, 2011 9:18 am
goose wrote:
biyitch wrote:Unless of course the previous owner already did this mod and didn't mention it :sekret:
Most likely.
cobraBLACK
Post by cobraBLACK » Tue May 17, 2011 9:25 am
I've heard people say the B7 S4 has the same part as the B7 RS4 but then I've also heard people say they've tried to upgrade only to find the previous owner already did it.
I guess the best way is to compare the part numbers on VAGCat or something (although is it possible they could be the same thickness but the RS4 one longer, resulting in a different part number?).
Scotty
Post by Scotty » Fri May 20, 2011 9:04 pm
goose wrote:Unless of course the previous owner already did this mod and didn't mention it :sekret:
I sold my B6 with it on so I'm sure there's many people thinking "these don't understeer lie Clarkson said they did" :lol:
B8 A4 Avant quattro
Honda CBR1100XX Super Blackbird
Suzuki GSXR1000 (Track bike)
B6 S4 (AMD Stage 3) - GONE
8N TT (APR/AMD/MTM) - GONE
cobraBLACK
Post by cobraBLACK » Fri May 20, 2011 9:20 pm
I measured mine when it was up on a ramp before I invested.
Post by Ian_C » Sat May 21, 2011 10:53 am
Sharkfan wrote:Hi,
Cheers,
Copied from another thread:
2no A8AO 511 439 Clip @ 4.16 ea + vat
1no A8EO 511 409 AL Stabilizer Bar @ £53.77 ea + vat
2no A8EO 511 327 D Y34 Mounting Bush @ 2.44 ea + vat
4no AN 101 277 07 Z21 Bolt Hex @ 0.64 ea + vat (although can use old ones)
