Milltek - what to do with exhaust flap line
coullstar
Post by coullstar » Sun Apr 24, 2011 3:12 pm
Was having a look under the car in preperation for fitting the Milltek exhaust and never even realised the S4 has the exhaust flap. Is there a procedure to follow with the flap vacum system plugging when fitting aftermarket exhausts?
B5 RS4
99 - Carerra 2
05 - T5 shuttle daily.
1781cc
Re: Milltek - what to do with exhaust flap line
Post by 1781cc » Sun Apr 24, 2011 3:24 pm
yeah, there is a guide on here somewhere (search), I did it but dont think it does much, flaps get stuck so you will need a long screwdriver, WD40 and a hammer!
I ended up getting a full non-res miltek with full decatted racing downpipes instead :-))
coullstar
Post by coullstar » Sun Apr 24, 2011 5:14 pm
Im away to fit a Milltek so need to disconnect / reroute the vacum lines, I did a search but nothing came up.
Im not bothered about anything to do with it on the standard system.
B5 RS4
99 - Carerra 2
marv
Post by marv » Sun Apr 24, 2011 11:39 pm
As you're going aftermarket, it doesn't really matter what you do with it I don't think. I've seen some people have plugged the pipe with an appropriately sized screw, and cable tie it out of the way somewhere.
| '04 S4 Avant (B6) | NOW SOLD :(
1781cc
Post by 1781cc » Mon Apr 25, 2011 7:11 am
sorry, I slightly misread what you were asking. the fitters should sort out what to do with them, I know MRC did with mine
coullstar
Post by coullstar » Mon Apr 25, 2011 10:56 am
Im fitting it myself.
B5 RS4
99 - Carerra 2
1781cc
Post by 1781cc » Mon Apr 25, 2011 7:31 pm
I'll get my coat
Pie
Post by Pie » Tue Apr 26, 2011 11:44 pm
Graeme,
Not sure if the S4 has an air box flap as well like the RS4;
If not and the vacuum pipes only run to the exhaust and nothing else, you can either leave it or shove a bolt down it to plug it and prevent the system from sucking up dust and crap from the road.
If the vacuum system is shared with another air-controlled system on the car, you will need to plug so the other system still operates.
I'd be tempted to plug regardless.
Do a search on the B7 RS4 forum for more info.
3.141
_________________________________
'14 C63 AMG Edition 507
'07 B7 RS4 +Milltek Non-Res, Non-Valved (Sold)
'10 YZF R1 + Akrapovics
Users browsing this forum: No registered users and 328 guests
