VAG-COM Diagnostic Test
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
Bluebrakes
Post by Bluebrakes » Fri Jun 13, 2008 8:21 pm
VAG-COM Version: Release 409.1-US
Chassis Type: 8D - Audi A4 B5
Scan: 01,02,03,08,15,17,25,35,45,55,56
Address 01: Engine
Controller: 8D0 907 551 D
Component: 2.7l V6/5VT G 0002
Coding: 05711
Shop #: WSC 01972
2 Faults Found:
17536 - Fuel Trim: Bank 1 (Mult): System too Lean
P1128 - 35-00 - -
17538 - Fuel Trim: Bank 2 (Mult): System too Lean
P1130 - 35-00 - -
Readiness: 0000 0000
Address 03: ABS Brakes
Controller: 8D0 907 389 E
Component: ABS/ESP allrad D36
Coding: 04395
Shop #: WSC 06435
No fault code found.
Address 08: Auto HVAC
Controller: 8D0 820 043 N
Component: A4
Note: Excessive Comm Errors
Skipping Address 15-Airbags
Address 17: Instruments
Controller: 8D0 920 980 B
Component: B5-KOMBIINSTR. VDO D11
Coding: 00464
Shop #: WSC 00000
ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ AUZ7Z0Y1412007
Address 25: Immobilizer
Controller: Bit teA dre ss
Component: e 17 eingeben
No Faults Found
or DTCs not supported by controller
or a communication error ocurred
Address 35: Centr. Locks
Controller: 8D0 862 257 E
Component: CV-Pump, Alarm, RC D13
Coding: 13130
Shop #: WSC 06325
6 Faults Found:
01371 - Alarm triggered by Door Contact Switch: Driver's Side
35-00 - -
01374 - Alarm triggered by Terminal 15
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
00955 - Key 1
09-00 - Adaptation Limit Surpassed
00956 - Key 2
01134 - Alarm Horn (H12)
49-00 - No Communications
Address 45: Inter. Monitor
Controller: 4B0 951 173
Component: Innenraumueberw. D03
Coding: 00101
Shop #: WSC 06325
2 Faults Found:
01382 - Alarm triggered by Anti-Theft Sensor: Front Left
35-00 - -
01383 - Alarm triggered by Anti-Theft Sensor: Front Right
35-00 - -
Address 55: Xenon Range
Controller: 4B0 907 357
Component: LEUCHTWEITEREGLER D004
Coding: 00012
Shop #: WSC 06325
Address 56: Radio
Controller: 4B0 035 186 E
Component: Radio 0001
Coding: 00017
Shop #: WSC 06325
End --------------------------------------------------------------------------------------------------
Any ideas what's likely to be causing the engine to be running lean? or so vag-com says anyway.
MAF sensor?
Oxygen Sensor?
Also does anybody know where the alarm module/sounder is located?
The indicators flash but no sound.
Blue_Thunder
RE: VAG-COM Diagnostic Test
Post by Blue_Thunder » Sat Jun 14, 2008 10:41 am
Press 'Search'!!!
Bluebrakes
Post by Bluebrakes » Sat Jun 14, 2008 8:16 pm
Well I did a search whilst I was waiting a resonse on the thread, which leads to the MAF sensor.
I just thought I would ask the experts. lol
OK, any ideas on the best place to buy a stock MAF sensor? Just a regular 2000 S4 MAF sensor. Or should I just 'search' ;-)
Why do they call it rush hour when nothing moves!?!
Standard S4, but not for long.
TopBear
Post by TopBear » Sat Jun 14, 2008 9:16 pm
Euro car parts are the cheapest
:blackrs4: B5 RS4, MRC Remap, Milltek, RS6\B7 Brakes, Black\Carbon
S4
Post by S4 » Sun Jun 15, 2008 12:10 am
Audi are best if you are keeping the car for more than 1 year, as you will get 2 years warranty from them.... its about 78 + vat I think.... its an exchange unit.
Darren
travs
Post by travs » Sun Jun 15, 2008 8:29 am
Alarm modue is in the driver's side rear wheel arch - get to it through the boot and then the access panel on the right. Been told its not hard to get to.
Is not the brain of the thing, just the hooter, but I think there is some resetting when you plug it back in - can't remember specifically though.
Written-off: Night Blue Metallic S6 5.2 V10 - Private plate, LED interior kit.
Sold:
Hibiscus Red Metallic S4 (B5 99.5) w/AmD Stage 1 Remap, RS4 Exhaust w/ Gutted Precats & R32 Tailpipes, Afterun Sensor, H&R Coilovers
Bluebrakes
Post by Bluebrakes » Sun Jun 15, 2008 11:33 am
Thanks Guys. I've just e-mailed euro car parts, as they didn't have any parts listed on the site. I'll check out my local audi garage as well.
I've been told its more than likely down to the back up battery, which is situated inside the alarm sounder or hooter.
Does this make sense?
Blue_Thunder
Re: RE: VAG-COM Diagnostic Test
Post by Blue_Thunder » Sun Jun 15, 2008 12:13 pm
Bluebrakes wrote:Thanks Guys. I've just e-mailed euro car parts, as they didn't have any parts listed on the site. I'll check out my local audi garage as well.
It makes perfect sense. As does pressing "search", then typing in Alarm Siren and choosing S4(B5) forum.
Shed loads of threads brought back. I spent 60 seconds reading through some and found this... http://www.ttoc.co.uk/howtoalarmsiren.php
See... easy!
Bluebrakes
RE: Re: RE: VAG-COM Diagnostic Test
Post by Bluebrakes » Sun Jun 15, 2008 2:11 pm
Thanks Blue Thunder for your patience.
Bluebrakes
Post by Bluebrakes » Mon Jun 16, 2008 4:41 pm
:D The good news i've fixed the alarm.
:? The bad news is the alarm sounder is really feeble.
So i may have to relocate it or do a mod on the alarm to make it louder.
One less fault code. ;-)
tartan_rob
Post by tartan_rob » Mon Jun 16, 2008 6:03 pm
Do MAF readings before splashing out on a new one. Or disconnect it and see if the car runs better or the same. If the car runs worse, the maf is fine.
MAF readings are the best though. 3rd gear from 2k to redline.
2017 Kawasaki Z1000
2014 RS6
2014 S1
Bluebrakes
Post by Bluebrakes » Mon Jun 16, 2008 6:49 pm
Definately the MAF, I did some readings using VAG-COM and the peak reading was 113.
Soon as i unplugged it, the car went like a rocket.
Downside is, the ABS and traction control is disabled when you unplug it. As i soon found out. Nice fat 11s on a B road. ;-)
I've got a new one on order.
Bluebrakes
Post by Bluebrakes » Thu Jun 19, 2008 7:32 pm
Installed the new MAF sensor. Certainly better. But it somewhat doesn't feel as purky as when it was disconnected.
I made sure I cleared all the fault codes before test driving.
I also changed the coding on the central locking module - so my car now beeps when locking and locks after 15mph. :-)
I shall do some tests tonight to see what the readings are.
Bluebrakes
Post by Bluebrakes » Fri Jun 20, 2008 8:44 pm
You can't beat an MRC health check.
Had one done today. Excellent guys.
Also found that the diverter valves were f****ed.
All sorted.
