Gearbox oil information
QuantumJohn
Hi guys,
I have searched high and low for this but really need any anwser.
I understand that there should be approx 3 litres of oil in the gearbox. Can someone confirm this as I have read on the Audiworld site it should be nearer 4.2 litres with the gearbox and rear drive/transfer box?
There are 2 drain plugs, 1 on the fined casing of the actual gearbox and 1 on what I imagine is the transfer box at the back of the gearbox.
Does the one filler fill both these boxes i.e. are they all one? Does the 3 litres account for both of them?
Why have 2 drain plugs?
Thanks,
John
Thanks,
John
- ChipHazzard
RE: Gearbox oil information
John
The gearbox holds just short of 3.5l I'll try and sort you the info from elsa later on when I get home, assuming her indoors doesnt want to take a quick spin down the test track to bluewater
Mike
Mike
FL Noggy S4 Avant
Kwack ZX7R & DRZ400 supermoto
QuantumJohn
- ChipHazzard
IIRC the drain bolt on the box is on the underside and the filler is on the side by the driveshaft. I'm not sure if this does both the oil is 45/90, give me a bell later to remind me and i can pop up if you like and bring my laptop with me
FL Noggy S4 Avant
QuantumJohn
Spot on John
From memory (Failing) thought it was 2.5L, anyway I checked the level with a bit of bent wire 7mm down from fill hole, depending on who you speak to our boxes are/not sensitive to this. Also Motul 300 75w-90 was recommended so used that.Does the 3 litres account for both of them?
Just a thought, I made sure I could undo the fill plug before I drained the oil, sure you will do this.
S4B5 Avant
Should be ~3 litres for the correct level (I am sure you can get more in!). The correct level
should be just below the fill hole. Pretty hard to gauge this on jackstands though as the
car has to be level. Asked Doug to check mine last time, when he pulled the plug about 1/2 litre
of oil poured out. To drain, you remove both the plugs on the underside. There is only one fill
hole which is on the NS of the tranmission casing, above the NS driveshaft.
Don't use a GL5 gear oil. I believe these have a high sulphur content which isn't great for brass synchros.
Remove the filler plug before removing the drain plugs. This helps with draining AND enables you to put
oil back in after draining. Apparently it's quite common to drain the transmission then not be able to
remove the filler plug to get oil back in!.
I think a fully synthetic 75w-90 is what is needed. Personally, I would get this from Audi.
MY 2000 S4
Ebony Pearl
Stage 3 (MRC 400 (ish))
Apexcone 50w HIDS
Ebony Pearl
Apexcone 50w HIDS
QuantumJohn
Thanks. I've also read that. Some people say 7mm below filler hole and the bently manual mentions up to the filler hole.MCB wrote: From memory (Failing) thought it was 2.5L, anyway I checked the level with a bit of bent wire 7mm down from fill hole, depending on who you speak to our boxes are/not sensitive to this. Also Motul 300 75w-90 was recommended so used that.
I didn't check the fill plug first but then not much point as the gearbox is going to have to come out anyway.
Thanks,
John
QuantumJohn
The gearboxes aren't just splash fed, they have a pump to get the oil up to the cooler and back.jacko788 wrote:guys stop being so pedantic please ur scaring owners away always fills gearboxes up to the filler hole till it just runs out,its splash fed so not that critical surely as long as u keep an eye on things.
John
BRETTCOLLINS
- 5th Gear
Users browsing this forum: Bing [Bot] and 58 guests
