Fast Road/Trackday Brake Pads
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
a.d.grant
Post by a.d.grant » Fri Jun 03, 2005 12:35 pm
What are the options other than EBC Greenstuff keeping brakes standard other than changing the pads to cope with the high temperatures generated by track use - standard audi pads are just not up to the job with their high wear rate and inability to cope with the heat build up.
I know this has been discussed before but my searches did not really give me an answer - hense the post here
tartan_rob
RE: Fast Road/Trackday Brake Pads
Post by tartan_rob » Fri Jun 03, 2005 2:11 pm
I have used Gren Stuff before, initially they are poo then for 3 or 4k miles they are great then they went worse than std. That was on a Fiat Uno Turbo 1.3 running 160bhp. My dad found exactly the same on His Saab Aero running 230bhp.
2017 Kawasaki Z1000
2014 RS6
2014 S1
wazza
Post by wazza » Fri Jun 03, 2005 2:20 pm
Not worth it IMO.
If you get pads that can be used at higher temperatures, then your brake fluid will boil easier.
If you change your brake fluid then the next weak link are the disks which warp under excessive use.
Been there, done that, and got the receipts to prove it (3 sets in a year :cry: )
Either upgrade properly (AP/Movit/Porsche) or accept the standard brakes for what they are.
Paul
tartan_rob
Post by tartan_rob » Sat Jun 04, 2005 12:14 am
To be honest, I have changed my oil for DoT 5.1 racing and gone for new discs and pads from Audi. The brakes are quite dull when cold or at low speed but at normal speeds 30mph+, I have had no problems at all, but I supose it depends on your tyres/suspension combination as well..?
PS BiTurbo - whereabouts are you in relation to magic roundabout?
2017 Kawasaki Z1000
2014 RS6
2014 S1
eatthis
Post by eatthis » Sat Jun 04, 2005 7:58 am
did u get standard pads and disks from audi??
too much is NEVER enough
14.7 1/4 mile golf vr6 highline
wazza
Post by wazza » Mon Jun 06, 2005 12:00 pm
Tartan_Rob wrote:PS BiTurbo - whereabouts are you in relation to magic roundabout?
Ahhh. The other Magic Roundabout :wink:
eatthis wrote:did u get standard pads and disks from audi??
Audi only sell one type.
I have tried both green and red from EBC, and also even had a set of standard audi disks machined to add the grooves in.
Paul
Nige_RS4
Post by Nige_RS4 » Mon Jun 06, 2005 3:40 pm
I am very happy with my current setup for fast road use - pagid fast road pads + DBA drilled & slotted + castrol SRF equivalent fluid.
If you are planning to do a number of track days, you should consider spending money on some proper brakes for the car, as it is a heavy beasty to slow down from high speeds.
tartan_rob
Post by tartan_rob » Mon Jun 06, 2005 5:50 pm
Yep std pads + discs from Audi. They weren't cheap but as they do they job (for my use) I ain't fussed. I do both Magic roundabouts twice a week....Swindon to Hemel....
2017 Kawasaki Z1000
2014 RS6
2014 S1
a.d.grant
Post by a.d.grant » Thu Jun 09, 2005 12:52 pm
Hey Nige S4 - which Pagid pads do you use :?:
Also - DBA disks, not heard of these and what is the crack :?:
Also - anyone know what brake fluid Audi Main Dealers put in :?:
Druggie
Post by Druggie » Thu Jun 09, 2005 1:20 pm
DBA disc are from Australia check out www.dba.com.au
Tony
S4- Possession without prescription is illegal
2000 S4 Silver, currently stock
Nige_RS4
Post by Nige_RS4 » Thu Jun 09, 2005 1:53 pm
They are pagid fast road material - apparently a harder compound than the normal fast road stuff, but not quite as harsh as the pagid blue + no squeal + no noise + same price as OEM pads = sensible choice for road use.
a.d.grant
Post by a.d.grant » Thu Jun 09, 2005 2:20 pm
Thanks Nige - checked out DBA website and I guess you have the 4000 rotors?
Users browsing this forum: No registered users and 104 guests
