Drive belt tensioner pulley "fell" off....
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
tartan_rob
Post by tartan_rob » Wed Nov 10, 2004 5:19 pm
How much do Audi charge for changing the drive belt and tensioner? I've just replaced the drive belt and tensioner in about 3.5 hours and that included flushing through my intercoolers and replacing jubilee clips around turbo hoses......
This job is straighforward, not much space so my hands are shredded but quite straightforward and saved me a small fortune and the lead time on the repair...! :D
gavsteryoung
Post by gavsteryoung » Wed Nov 10, 2004 7:41 pm
I've been quoted just under £500 inc Vat by Audi and QST. That includes the water pump too.
My local VW garage quoted £380 inc Vat but I think they are chancers!
UKS4APR1
Post by UKS4APR1 » Wed Nov 10, 2004 11:17 pm
Changing the water pump is a whole new ball game to changing the auxilliary drive belt tensioner!
On a previous post I have recommended changing cambelt, waterpump and anything else which rotates (belt tensioners), all at the same time. It's no mean feat and hugely sensible to do everything at the same time whilst you are at it.
I did mine at 72k, water pump was noisy and just starting to leak, tensioners were on their way and belt looked ropey. Took me all afternoon to strip and then two nights to put back together including welding up an alignment bar to lock the cam sprockets in position (also highly recommended)
It's certainally not a job for an inexperienced home mechanic and don't forget to buy some G12 anti-freeze for refilling afterwards.
There is also an issue with Audi water pumps where the nylon impeller falls off resulting in (difficult to diagnose) overheating.
Pumps supplied now have been modified.
Julesm
Post by Julesm » Thu Nov 11, 2004 8:59 am
UKS4APR1 wrote:. Took me all afternoon to strip and then two nights to put back together including welding up an alignment bar to lock the cam sprockets in position (also highly recommended)
Why did you have to weld up an alignment bar?
UKS4APR1
Post by UKS4APR1 » Fri Nov 12, 2004 12:34 am
The alignment bar holds/locks the sprockets in position whilst you fit the new belt.
Because of the position of the cams with some valves partially open, they (the cams) want to flick round and so lose their position (timing). I assure you that if you don't lock them into position they will spring round, especially the RH cam making it very difficult to fit the new belt correctly.
The bar is quite simple to make [assuming you have a welder] just get a straight length of sturdy/rigid bar or box section and weld on 4 bolts to line up with the two pairs of holes provided in the cam sprockets. You do this before you remove the old belt to ensure a perfect alignment.
Getting the new belt on is pretty tricky, always seems like it's a touch too short! [even though it's got the same number of teeth as the old one!].
The belt tensioner is sprung and oil damped so at least there's no problem setting up the correct tension.
Mo_S3
Re: Drive belt tensioner pulley "fell" off....
Post by Mo_S3 » Sat Nov 13, 2004 1:20 pm
Tartan_Rob wrote:and that included flushing through my intercoolers :D
Can you explain a bit further please ??
tartan_rob
Post by tartan_rob » Mon Nov 15, 2004 3:42 pm
Very hot soapy water and lots of hot water thereafter. A lot of crap came out (well a lot considering there are filters etc in place). I had the same thing a long time ago on my Uno turbo.
2017 Kawasaki Z1000
2014 RS6
2014 S1
