Wich gear on rolling road
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
matias
Post by matias » Sun Sep 21, 2008 2:51 pm
Is it normaly to run the car in 6. gear on a rollingroad?
Blue_Thunder
RE: Wich gear on rolling road
Post by Blue_Thunder » Sun Sep 21, 2008 5:38 pm
4th.
MGR
Post by MGR » Sun Sep 21, 2008 8:07 pm
I thought it was generally done in the ratio that is the direct one. i.e. 1:1 so thats quite often 5th gear in a 6 speed car as the 6th is an overdrive gear for crusing. In my BMW it was done in 5th and it is a 5 speed box.
Blue_Thunder
Post by Blue_Thunder » Sun Sep 21, 2008 10:39 pm
An S4 would be doing 140+ at the redline in 5th!
dubwhizz
Post by dubwhizz » Sun Sep 21, 2008 10:54 pm
and you dont want it jumping off the rollers at 140!!!
Matt
MGR
Post by MGR » Sun Sep 21, 2008 11:11 pm
Yes thats true, but my BMW is doing 170 mph at the red line and it was done in 5th gear.
Also remember that the power quoted will change depending on what gear you use as the transmission loss and general heat loss and friction is higher in higher gears. The coast down doesn't always compensate for this properly. You should always use the same gear for direct comparisons.
If your car jumps off the rollers even in 2nd gear then its going to be a write off no matter what.
Philws4
Post by Philws4 » Mon Sep 22, 2008 7:48 pm
Last RR i went too the runs were done in 3rd, still gets up to circa 100 mph :wink:
B5 S4
Blue_Thunder
Post by Blue_Thunder » Mon Sep 22, 2008 7:54 pm
MGR wrote:If your car jumps off the rollers even in 2nd gear then its going to be a write off no matter what.
Maybe not - http://www.youtube.com/watch?v=p4l-Dl73TpM&NR=1 :shock:
Blue_Thunder
Post by Blue_Thunder » Mon Sep 22, 2008 7:57 pm
And from that, just found this clip. Hilarious!
http://www.youtube.com/watch?v=GSl-jSfn ... re=related
Poor old sod!
Stigter
Post by Stigter » Mon Sep 22, 2008 8:43 pm
Thats ace Scott.
MGR
Post by MGR » Mon Sep 22, 2008 10:05 pm
Oh dear - I suppose that comment was meant if it was properly strapped down so it can't move, and so the only way it is coming off is if the rollers jam.
dubwhizz
Post by dubwhizz » Tue Sep 23, 2008 3:08 pm
i have heard a rumour that a car that does jump will stall instantly. not sure if thats truth or not.
matias
Post by matias » Tue Sep 23, 2008 4:48 pm
Here they are rolling the car in 6. gear..
curtis11
Post by curtis11 » Tue Sep 23, 2008 6:15 pm
4th gear
