Anyone know how much they are and how they are held into the hub?
keep getting the DIS flash up evey now and then.
Cant be much of a job!
Your help please.
PS Anyone got one spare to try/buy??
ABS Sensor
RE: ABS Sensor
They just push in. Get under the car and see. Mine fell out when having the Sh1t pounded out the pinch bolt when trying to replace the control arms. I was amazed at how poor the push fitment was. Then test with vagcom. I bet you might be able to reach if you just slide under the car on the street. Sensor is located towards the front of the upright
RE: ABS Sensor
I think VagCom will tell you if one is dead and some fall out as mentioned and some can be a real beetch to get out!
S4B5 Avant
RE: ABS Sensor
Check with Vag-Com but you may have a problem with the ABS module itself, it's a common problem. You can get them repaired for £100. I recently changed my rear wheel bearings and tried to take the ABS sensor out, totally seized. Snapped off in the end and had to repalce it, £80. When I did the other side I disconnected the sensor from under the rear seat instead.
B5 S4
B8.5 S4
B8.5 S4
RE: ABS Sensor
In fact now I think about it I would rather replace the ABS module again than have to try to remove another wheel sensor!!
B5 S4
B8.5 S4
B8.5 S4
