ABS Sensor
2.7 V6 30v biturbo - 251bhp
2.7 V6 30v biturbo - 261bhp
Trig
ABS Sensor
Post by Trig » Thu May 01, 2008 7:28 pm
Anyone know how much they are and how they are held into the hub?
keep getting the DIS flash up evey now and then.
Cant be much of a job!
Your help please.
PS Anyone got one spare to try/buy??
Stigter
RE: ABS Sensor
Post by Stigter » Thu May 01, 2008 7:31 pm
They just push in. Get under the car and see. Mine fell out when having the Sh1t pounded out the pinch bolt when trying to replace the control arms. I was amazed at how poor the push fitment was. Then test with vagcom. I bet you might be able to reach if you just slide under the car on the street. Sensor is located towards the front of the upright
MCB
RE: ABS Sensor
Post by MCB » Thu May 01, 2008 9:38 pm
I think VagCom will tell you if one is dead and some fall out as mentioned and some can be a real beetch to get out!
S4B5 Avant
Danian
RE: ABS Sensor
Post by Danian » Fri May 02, 2008 9:49 pm
Check with Vag-Com but you may have a problem with the ABS module itself, it's a common problem. You can get them repaired for £100. I recently changed my rear wheel bearings and tried to take the ABS sensor out, totally seized. Snapped off in the end and had to repalce it, £80. When I did the other side I disconnected the sensor from under the rear seat instead.
B5 S4
B8.5 S4
Danian
RE: ABS Sensor
Post by Danian » Fri May 02, 2008 9:50 pm
In fact now I think about it I would rather replace the ABS module again than have to try to remove another wheel sensor!!
B5 S4
B8.5 S4
