Help.. K&N vs Pipercross vs BMC
RE: Re: RE: Re: RE: Re: RE: Help.. K&N vs Pipercross vs
Honest answer is I dunno Jimbo - all I know is that my car runs great with the BMC, and I have no MAF problems.
From what I remember of the graph plots comparing the filters the BMC curve was above all of the others pretty much across the entire rev range (i.e. it showed higher g/s flow)
Works well for me and Paz .... will it work for you? ... who knows!
Deus ex machina
Re: RE: Re: RE: Re: RE: Re: RE: Help.. K&N vs Pipercros
Ok I'm prepared to be the guinea pig Ive got a brand new oem paper filter in at the moment so will buy a BMC and log and publish both sets of results. however I'm going away on Friday morning so will need to get a BMC filter today any ideas where. I'm in the weybridge area of SurreyS4TAN wrote: Works well for me and Paz .... will it work for you? ... who knows!
Jimbo
RE: Re: RE: Re: RE: Re: RE: Re: RE: Help.. K&N vs Piper
Hardly a guinea pig ... me and Paz both have one already! (and Phil has one on order)
Good idea to do some logs - be good to see if your measurements show a higher flow than the paper.
There's a link further back in this thread to an online seller of BMC filters - if you order today you may get next day delivery ... other than that I wouldn't know where to get one.
Deus ex machina
Re: RE: Re: RE: Re: RE: Re: RE: Re: RE: Help.. K&N vs P
No not a guinea pig exactly just referring to Nige and Graham who are currently sitting on the fence!S4TAN wrote:Hardly a guinea pig ... me and Paz both have one already! (and Phil has one on order)![]()
Anyway part now ordered from Edworthys £40.98 including VAT and delivery.
If it arrives tomorrow i will post results that evening if not it will be Teusday or Wednesday.
jimbo
RE: Re: RE: Re: RE: Re: RE: Re: RE: Re: RE: Help.. K&N
Got any IPA spray to clean your MAF sensor first Jim?
Deus ex machina
jimbo
Let us know how it goes. I think my local Edworthys is gone now, I think they have gone internet only.
Present: 2010 Ice silver B8 S4 s-tronic saloon (standard)
Past: 1998 Agate grey B5 S4 saloon (MRC tuned)
Hers: 2011 Volcano red 8P A3 Sportback 2.0 TDI 170 sport quattro
Re: RE: Re: RE: Re: RE: Re: RE: Re: RE: Re: RE: Help.. K&am
If IPA is Carb Cleaner then yes! or thats what ive been using. Generally change air filter and clean MAF every 5k the the oem paper version as with holes in the airbox it gets dirty pretty quick. Can you clean the BMC version, because replacing that on such a regular basis would prove expensive.S4TAN wrote:Got any IPA spray to clean your MAF sensor first Jim?
@ Graham will definately post results ASAP
RE: Re: RE: Re: RE: Re: RE: Re: RE: Re: RE: Re: RE: Help..
You sure can - and you wouldn't need to replace as often as a paper filter anyway.Can you clean the BMC version, because replacing that on such a regular basis would prove expensive.
Deus ex machina
- Top Gear
RE: Re: RE: Help.. K&N vs Pipercross vs BMC
AdamS4 wrote:Just fitted my BMC panel filter... and did some logs.
Was getting around 220g/s before, now around 227g/s.
So, a 7g/s improvement from dirty paper to clean BMC and 7g/s (thank you Julian) improvement from dirty paper to clean paper filter.jimbogrey wrote:achieved a peak maf of 274 g/s and a fats of 4.49 with a new oem paper filter!!! Interestingly peak maf with the old dirty filter was 267 so a 9BHP difference.
Perhaps someone should do a comparison with a brand new paper filter versus one of these panel filters...
Since when did 267>274 = an increase of 9? I make it 7 ... or has maths changed since I were a lad?
Think Doug already did that!Perhaps someone should do a comparison with a brand new paper filter versus one of these panel filters...
Deus ex machina
My paper airfilter wasn't that dirty either.... was only replaced 6 months ago.
Re: RE: Re: RE: Help.. K&N vs Pipercross vs BMC
7g/s = 9BHP approx.......should have gone to specsaversS4TAN wrote:Since when did 267>274 = an increase of 9? I make it 7 ... or has maths changed since I were a lad?
