S4 install RS4 intercoolers
Is it necessary to change S4 both sides lower and upper hoses when installing RS4 intercoolers? Or just change both the upper hoses will do......... Thank you for your input.
RE: S4 install RS4 intercoolers
when converting to RS4 intercoolers you have to use both top and bottom hoses from either an RS4 with a piece of s4 hose at the joint to take up the diff size in hoses or use RS4 to s4 hoses already made for the conversion..
GARTH ROAD MOT CENTRE LTD
020 83353032
020 83353032
I would suggest getting the hose conversion kit from Forge Motorsports if they still do it. This has the 4 reducing
hoses you will need. You will also need to source the lower intake hard pipe from the RS4 (offside I think). I assume
you realize you will also need all brackets, nuts and bolts etc. I can recommend Dialynx for the install, they did a pretty
good job (relatively speaking) of mine.
MY 2000 S4
Ebony Pearl
Stage 3 (MRC 400 (ish))
Apexcone 50w HIDS
Ebony Pearl
Apexcone 50w HIDS
Samco do a kit for the RS4 IC's on an S4 - about £65 from memory.
https://www.speedcams.co.uk
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
Ed 30 Golf DSG - gone
2018 Golf R 7.5
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
2018 Golf R 7.5
Re: RE: S4 install RS4 intercoolers
Yes, that's the kit I got from Forge.Nige_S4 wrote:Samco do a kit for the RS4 IC's on an S4 - about £65 from memory.
MY 2000 S4
Ebony Pearl
Apexcone 50w HIDS
Ebony Pearl
Apexcone 50w HIDS
Mine tooJonnyX wrote:Yes, that's the kit I got from Forge.Nige_S4 wrote:Samco do a kit for the RS4 IC's on an S4 - about £65 from memory.
BRETTCOLLINS
- 5th Gear
RE: Re: RE: S4 install RS4 intercoolers
takes over a month to get it,
MING BLUE AUDI S4
Car is on Lock down
506.9 BHP @ 6.020 RPM
445.0 WHP @ 5.981 RPM
481.5 IBFT @ 4.976 RPM
Car is on Lock down
APR pipe kit from ECS does the same job, dearer but usually in stock.
Try www.forgemotorsport.co.uk - they no longer stock Samco stuff, but might still be able to get the kit for you.
If you don't have any luck with Forge, try contacting Samco direct ... www.samco.co.uk
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
2018 Golf R 7.5
B5 2.7t S4 - gone
B5 2.7t RS4 - gone
2018 Golf R 7.5
Found this and thought it might be helpful... http://www.goapr.com/Audi/support/s4_in ... ctions.pdf
Mark
