VAG option decoder
VAG option decoder
To be made sticky
VAG option decoder's
http://igorweb.org/equidec/Default.aspx
http://itunes.apple.com/us/app/audi-opt ... 48112?mt=8
- Mr Footlong
Re: VAG option decoder
Going to try that in the morning, thanks!
/EDIT - Does exactly what it says on the tin:
E0A = No special edition
0GE = Emission standard EU3
4UE = Air bag for driver and front seat passenger
6XD = Exterior mirrors: electrically adjustable/heated
1KZ = Disc brakes, rear
J0Z = Battery 520 A (110 Ah)
1LJ = Disc brakes, front
2MC = Sports suspension with variable shock absorption
3FE = Electric slide/tilt sunroof with sun screen/sunblind
5TU = Decorative inserts, carbon with metal fibre
7X2 = Park distance control, front and rear
F0A = No special purpose vehicle, standard equipment
8GT = Compact alternator 90 - 150A
0G7 = Tiptronic
0YS = Weight range 17 installation control only, no requirement forecast
0JM = Weight category front axle weight range 12
T09 = 8-cylinder gasoline engine 4.2 L unit 077.A (aluminum)
3NZ = Rear seat bench unsplit, backrest split folding
8EC = Bi-functional headlight with gas discharge lamp, for driving on the left
U1D = Instrument insert w/ mph speedo, clock, tachometer, trip odometer and additionalinstruments (voltage, oil temperature)
X2B = National sales program Great Britain
1N1 = Power steering
1XY = Leather trimmed multi-function sports steering wheel w/ Tiptronic
3HK = Alcantara scope without leather
8Q3 = Automatic headlight-range adjustment dynamic (self-adjusting while driving)
9Q2 = Multi-function display/on-board computerwith check control
8Z5 = Not hot country
D0V = 8-cyl. gasoline eng. 4.2 L/331 kW 40V V8biturbo base engine is T09
7Q2 = Navigation system with color screen
CL5 = Alloy wheels 8.5J x 18
7K1 = Tire pressure warning light
4X3 = Side air bag front with curtain air bag
VJ4 = Reinforced bumpers
6R0 = Selector lever cover
3L5 = Electric seat adjustment for both front seats
VW1 = Side windows tinted green, from B-pillar to rear window gray tinted safety glass
3Y0 = Without roll-up sun screen
4K4 = Radio remote controlled central locking
5D1 = Carrier frequency 433.92 MHz-434.42 Mhz
1SA = Without additional engine guard
Q1E = RECARO sports seats, front
4GP = Windshield in heat-insulating glass withsunshield and viewing window for vehicle identification number
0G7 = Tiptronic
Current:
Gone:
Gone:
Awesome that is. nice find.
0GG = Emission standard EU4
4UF = Drivers and front passenger air bag with front passenger air bag deactivation
6XL = Exterior mirrors: with memory function, automatically dimming, electrically foldable/adjustable/heated
5SJ = Left exterior mirror: convex
6TS = Right exterior mirror: aspherical, large viewing field
1KJ = Disc brakes, rear
1LM = Disc brakes, front
1X1 = Four wheel drive
3FA = Without roof insert (standard roof)
5MR = Decorative inserts
7X8 = Park distance control, front and rear with rear view camera
4R4 = Power windows with comfort operation andcircuit breaker
8GH = Alternator 190 A
0G7 = Tiptronic
0YK = Weight range 10 installation control only, no requirement forecast
0JN = Weight category front axle weight range 13
TT7 = 10-cylinder gasoline engine 5.0 L unit 07L.B (aluminum)
U0F = Instrument insert with tachometer clock and mph speedometer
1N3 = Speed-related variable steering assist (Servotronic)
2FU = Leather trimmed multi-function sports steering wheel w/ Tiptronic
8Q5 = Headlight-range adjustment, automatic/ dynamic with dynamic bending light (AFS 1)
9Q4 = Multi-function display/on-board computerwith check control
D70 = 10-cyl. gasoline eng. 5.0 l/426 kW (40V)V10 FSI BIT Base engine is TT7
CY6 = Alloy wheels 9.5J x 20
7K3 = Tire pressure control, frequency 433 MHzhigh level version
4X4 = Side air bag, front and rear with curtain air bag
VJ3 = Reinforced bumpers
3L4 = Electric seat adjustment for both front seats, drivers seat with memory system
S0C = Introductory volume
4KF = Side windows in heat-insulating glass, from B-pillar and rear window dark tinted
4K2 = Radio remote controlled central locking "SZV"
5D7 = Carrier frequency 868 MHz without panic button
1SA = Without additional front underbody guard
Q4Q = Sports front seats
4GP = Windshield in heat-insulating glass withsunshield and viewing window for vehicleidentification number
0G7 = Tiptronic
There is an Audi option code calculator that I came across sometime ago. Will see if I can dig it out from the other forum.
As OP
simply type in the code and then click 'decode'
only suitable for up to 2012 VAG vehicles but may work with some later ones.
could handy threads, topics and how too's like these be made in to 'Stickys' under a column titled Knowledge Base.
Submitted by forum members based on their findings and experiences and regulated/locked by the moderators ?
You can use the 3 digit PR Codes found inside the Service book to find out all the options on your car here ...
http://prsearch.planetvag.com/
Current: None
Previous Audis: B9 RS4 Avant, B7 RS4 Avant, Mk3 TTS, Mk1 TT Quattro Sport 240
Difficult to grasp this. I’ve looked at my codes ( similar to the second entry above) but so much seems missing. No mention for example of the HUD, Bang & Olufsen, Sports exhaust and more that my RS5 has ?
What do the other codes ( in larger type on the options Sticker ) mean, such as DECA .
F53 on mine says 18” wheels, but mine are 20” . . .
Mine shows weird stuff too, especially for newer options.
