????Whining noise on boost????
BigMo
Post by BigMo » Sun May 03, 2009 3:50 pm
Thought the car was a tad bit jumpy today. Wound the windows down and could hear a whining noise when on full boost. Turbo up the spout? Anyone?
RS6 (MRC'd with econodrive) is not just for Xmas
Toyota Aygo Platinum for minimising carbon footprint.
BigMo
RE: ????Whining noise on boost????
Post by BigMo » Mon May 04, 2009 3:15 am
46 views and bump!!!! Anyone????
Cornishmoocher
Post by Cornishmoocher » Mon May 04, 2009 7:26 am
Not sure Mo, When my box went tits up it whinned like a bugger and obviously got worse the harder you pushed her. Could be a pully or tensioner. Or it could be your turbos. I know what i would do mate. I wouldnt be taking a chance, i'd head back to MRC to get them to check it out just in case it is a potential terminal problem, and hopefully catch it before it does go mahoosive.
It's all Bollox.
BigMo
Post by BigMo » Mon May 04, 2009 10:19 am
my thoughts exactomondo fella. Cheers.
BigMo
Post by BigMo » Mon May 04, 2009 2:18 pm
Bugger!!! Now the switch from 1st to 2nd is lumpy!!!!!
drybeer
Post by drybeer » Mon May 04, 2009 6:23 pm
then I feel sadly the 'box is donald ducked. Mine also made a turbine- whine when it became faulty.
C7 A6 allroad 3.0TDi.
Tiguan 2.0TDi R-line
BigMo
Post by BigMo » Mon May 04, 2009 6:57 pm
It's all going pete tong!!!! What next?
Cornishmoocher
Post by Cornishmoocher » Mon May 04, 2009 7:02 pm
Before you go getting morbid about your box..... Get the chaps at MRC/whoever you use but believe its MRC, to do gearbox oil change serivce.
When I had my box changed by Audi under warranty, the numpties left all the bolts in the sump apn loose. I was losing oil all the while. Eventually the box started to slip and whine. Emergemcy trip to Grizzly and after tightening up the bolts and addeing 4 or 5 ltrs of ATF, the thing has been right as reign ever since...... Its worth a try.
If you are covered by a warranty and your box has not been changed, it may well be worth doing it anyhoo, but just remember to get MRC to do it, that way you wll get to keep your box map AND the job will be done properly. (as a rule Audi will change the TCU too)
If you don't normally use MRC for this type of work, I would go to them or Grizz, I know Grizz has done laods of warranty work and the warranty boys know and trust him. I am sur MRC are in a similar position tho.
Cheers Mooch
It's all Bollox.
BigMo
Post by BigMo » Mon May 04, 2009 9:12 pm
I'll drop by Doug's over the next couple of weeks. The problem is more prominent when using the loud pedal, under normal driving conditions seems ok. Cheers for the advice chaps.
Doug_S2
Trader (Expired)
Post by Doug_S2 » Tue May 05, 2009 4:22 am
Time for a health check i think.
http://www.MRCtuning.com
BigMo
Post by BigMo » Tue May 05, 2009 9:59 am
anytime over the next two weeks Doug me old insomniac?
Doug_S2
Trader (Expired)
Post by Doug_S2 » Tue May 05, 2009 10:17 am
shoot lucas a call and he'll find a slot. Those monday mornings (tuesday on bank holidays) i come into work early.
BigMo
Post by BigMo » Fri May 08, 2009 9:08 am
Booked for Monday!!!!!!!
BigMo
Post by BigMo » Tue May 12, 2009 2:13 pm
She in the capable hands of Dr Doug and Dr Lucas!!!!! Pray!!!
MartynC
Post by MartynC » Tue May 12, 2009 5:47 pm
Our thoughts are with you at this difficult time Mo.
MartynC
Users browsing this forum: No registered users and 131 guests
