Fuse 29 interrupt switch
Posted: Mon Jan 17, 2022 10:11 pm
by Lander91
Quick hack share.
I drive my 6 only a few times a month and have noticed before that if I start it up after it's been sitting I get the top end rattle.
Pulling the #29 fuse, as outlined on this forum, and cranking it a couple of times for 7 or 8 seconds a time to get oil pressure up means a quiet start once the fuse is replaced.
It's a bit of a faff, so I decided to hook up a switched circuit for fuse 29.
Not the best looking end where the circuit plugs into the fuse location, but I works and is secure.
I hacked up a fuse to the solder the wires to it as using spade connectors was too loosey goosey.
Circuit has an inline fuse holder, then the switch is mounted in a hidden location.
Works a treat and means I can just get in the car and close the door, flick the switch go through the cranking process then hit the switch again for the proper start.
Anyway for reference if anyone wanted to try the same thing.
Re: Fuse 29 interrupt switch
Posted: Mon Jan 17, 2022 10:33 pm
by Shoppinit
That’s not a bad idea. Might do the same but without the spunk all over it.
Posted: Tue Jan 18, 2022 1:28 am
by Lander91
I can get a bit excited when it comes (pun?) to working on the 6.
Posted: Mon Jan 24, 2022 11:54 am
by mavada
Nice one, thats on my todo list shortly.👍
Posted: Mon Jan 24, 2022 5:20 pm
by Astrosquirrel
Awesome tip. Thanks! :)
Posted: Sat Apr 30, 2022 8:53 pm
by mavada
Posted: Sat Apr 30, 2022 9:07 pm
by Lander91
ATC/ATO by the looks. I searched high and low here locally for a solution like that. May need 90deg spade connectors depending on the installed height. Amazon here I come, thanks Mav.
Posted: Fri May 06, 2022 7:09 am
by ChrisA
Can you report back which one you went for and if you’re happy with it as I think my RS is about to move into the weekend winter car rather than daily driver.
I’d be happy to put together an order to build several kits if there’s a demand? (However I dare say there’s others on the forum with better soldering skills than mine 😊)
Posted: Fri May 06, 2022 7:17 pm
by Mɐʇʇ
Couldn’t you just floor it so it goes into anti flood mode to prevent starting?
Posted: Fri May 06, 2022 7:21 pm
by Shoppinit
Doesn’t work on the RS6. Now *that’s* a good way to shear a cam lobe. :)
Posted: Fri May 06, 2022 7:38 pm
by Mɐʇʇ
I was hoping one of you would try it for me. :mrgreen:
Posted: Fri May 20, 2022 9:37 pm
by Lander91
Haven't pulled the trigger yet. I've got a few other projects on the go. But it'll be the ATO/ATC version.
