On the road again...
Re: On the road again...
You could get a new nut and thread it on to the end of the bolt, but not all the way, then use a hammer to give a sharp tap on the end of the nut. The nut will protect the end of the bolt. I think wood will be too soft to break the bond.
Ill try...
Mugello Blue C5 RS6 Avant
Viper Tuning ECU/TCU
Yellow Koni's
Yellow Koni's
I smashed the nut i put on in different shapes...not a single movement.
Will try new nut and smash again. Try not to bend the bold i hope...
Yellow Koni's
Yellow Koni's
Try heating one side of the housing with a blow torch. Be very careful to protect the ball joints from the flame.
Mm i dont have one...
Ill let it soak for a while now.
Ive just turned the steering Wheel to the left, so i have a bit more space to slam it even harder...
Yellow Koni's
Yellow Koni's
Yellow Koni's
Yellow Koni's
Thinking about it, why not loosen the upper control arms at the top instead of at the pinch bold...?
Yellow Koni's
Yellow Koni's
Steve2003rs6
Having watched the video. No wonder the garage knackered my hub. And I had to get a new one.
Yeah, that might work. Assuming those bolts aren’t stuck, too.
Not sure how much flex those upper controlarms have when loose from top but still connected to the pinch bold, so the shock can be taken out...?
Yellow Koni's
Yellow Koni's
I would like to know the part number of the pinchbold and nut.
I think it has to be replaced anyway when i go that route...
"What tends to happen is the bolt is slightly bent at the split. So just removing the nut and trying to hammer it out is effective trying to drive a bent bolt through a straight hole. Easiest method is to use a hacksaw and cut the bolt through at the split. Then thread the nut on and as you tighten it , it will pull the now cut threaded piece through. You will have to put washers or a spacer under the nut once you get to the shank of the bolt but it only takes a few tries. Once this is out, you now have a clear shot at punching out the remaining part of the bolt. As the bolt is no longer bent/pinched it will punch out easy, even if it's corroded."
Yellow Koni's
Yellow Koni's
Bold: N 0347908
Nut: N 10272302
Nut: N 10272302
Yellow Koni's
Yellow Koni's
*bolt
Yellow Koni's
Yellow Koni's
*bald
Users browsing this forum: No registered users and 160 guests
