So it wasn't the starter motor...
srichards
Re: So it wasn't the starter motor...
Post by srichards » Mon May 20, 2024 8:27 am
Autodoc again! https://www.autodoc.co.uk/metzger/20296381
There are cheaper ones but this is a brand I've heard of vaguely and supposedly are ok.
Post by Shoppinit » Mon May 20, 2024 8:31 am
Cool. I think I would have made the same choice.
Hopefully it'll fit OK and we can confirm that 01V919821B is equivalent to 01L919821B. I'm 99% sure it is anyway.
/Just checked and the cheapo part I ordered was 01V919821B. It looked identical to the previous F125 in the junk parts box, IIRC.
srichards
Post by srichards » Mon May 20, 2024 9:45 am
Now we wait until it arrives <hold music>
srichards
Post by srichards » Tue May 28, 2024 1:37 pm
Switch has only just arrived. Bloody autodoc drive me insane sometimes. Stuck in their warehouse for days on end. It's always the stuff you are gnashing your teeth for that is delayed!
Not got any where with relays as none have exactly the same diagram as the 53 labelled one on the Deutsche parts site. Got a hella guess and also a Bosch guess. Neither look quite identical.
TOPMAN
Post by TOPMAN » Wed May 29, 2024 4:44 pm
Shoppinit wrote:Cool. I think I would have made the same choice.
Ben I think mechanically those 2 part numbers are the same, but one has a molex type plug and the other a round plug.
Regards
Craig
Post by Shoppinit » Wed May 29, 2024 6:04 pm
No, the plugs are the same.
TOPMAN
Post by TOPMAN » Wed May 29, 2024 6:21 pm
Shoppinit wrote:No, the plugs are the same.
Hmm Image guess my parts catalogue must be wrong then? That’s odd…
HPsauce
Post by HPsauce » Wed May 29, 2024 6:31 pm
Round plug is the old version, not sure on the part number but it's different, maybe just no suffix?
Edit: I think it's 0501209763
srichards
Post by srichards » Fri May 31, 2024 11:11 am
Dropped the car off. Even when the car hasn't got the PRND warning it's definitely thumping and possibly slipping. I may have finally lost the game of gearbox roulette :cry: :cry: :cry:
steve2003rs6
Post by steve2003rs6 » Fri May 31, 2024 11:51 am
That doesn’t sound good. Fingers crossed for you for a favourable outcome.
Post by Shoppinit » Fri May 31, 2024 1:14 pm
Any fault codes?
Maybe get them to replace the ATF and strainer. They can drop the valve body while they’re at it and check for split metal pipes.
srichards
Post by srichards » Fri May 31, 2024 1:56 pm
Gearbox was all serviced last year I think. Not done many miles since. It did the PRND flash last year when I first started it after winter but it behaved perfectly from then on the few times I used it. Caned it to Radwood and back and not squeak of bother.
I don't think it was chucking any codes before but I assume it will now. Hopefully it just moans about the switch and that it's just the switch again...
Post by Shoppinit » Fri May 31, 2024 4:00 pm
Yeah. Hopefully.
steve2003rs6
Post by steve2003rs6 » Fri May 31, 2024 4:49 pm
Fingers crossed.
srichards
Post by srichards » Fri May 31, 2024 5:03 pm
Everything is crossed!
Users browsing this forum: Bing [Bot] and 31 guests
