Gearbox fault
Frazz82
Re: Gearbox fault
Post by Frazz82 » Sat May 06, 2023 8:05 pm
Riiiiiiight some progress. Got the drivers carpet lifted an it was soaking wiring is wet but doesnt look corroded and the box that the TCU in is bone dry. So hoping drying it all out will sort it.
Just need to find if its the air con drain thats been suggested or the ecu box an bonnet pull in the scuttle.
Frazz82
Re: Gearbox fault
Post by Frazz82 » Sun May 07, 2023 1:56 pm
I ve dropped the glovebox an taken the heater box air con drain pipe out so I can check the hole through the bulkhead. Before I go and start ramming a screwdriver through should this be clear to begin with or is it chances are its really cloggged up.
Re: Gearbox fault
Post by Shoppinit » Sun May 07, 2023 2:04 pm
I have had a blocked AC pipe on a car before. It caused corrosion and made the chassis VIN unreadable, effectively writing off the car.
I wouldn't use a screwdriver. IIRC the drain has a kink in it and drains along the chassis under the car. Use low pressure compressed air or something. Or pour some water in to see if it drains.
Frazz82
Re: Gearbox fault
Post by Frazz82 » Sun May 07, 2023 6:00 pm
Cheers I will do that.
Is there anything aircon related on the OS that could cause water ingres. I am struggling to see how that drain on the NS would cause water to pool in the OS.
Felix2566
Re: Gearbox fault
Post by Felix2566 » Mon May 08, 2023 9:13 am
From what I have read the plastic cradle that the cabin filter sits in has a foam seal at the bottom of it. This fails and lets water in from there into the passenger footwell....(RH drive cars)
Frazz82
Re: Gearbox fault
Post by Frazz82 » Mon May 08, 2023 7:02 pm
Cheers mate. All the water is in the O/S (UK car)
Users browsing this forum: srichards and 118 guests
