So long story short I got a tranny limp mode a month or so ago and it puts me in 4th gear
Restarting the car it will usually disappear then reappear within 5-10 minutes of driving.
Used Vagcom and found code solenoid 3 (N90) short to ground.
Ordered all new solenoids but they sent the wrong
6,7,8 solenoids
Got the correct ones in and after 20 minutes of driving BAM back in limp mode.
What I’ve tried:
-Ensuring correct ATF levels/clean etc
-Checking TCU and cleaning the connectors with contact cleaner (no corrosion) however I do get some dampness in the passenger footwell carpet from time to time
-checking the reading between pin 4 and 16 on the harness at the front of the trans (reading fine) and cleaning that connection
I’ve read a ton of forums on this but feel at a loss, any help is much appreciated
