The dreaded PO of mine didn't...he had a perfectly good Daytona Avant bare metal re-sprayed in Ibis
2003 RS6 Build thread
- Weiß-sechs
- 5th Gear
- Location: Everywhere & nowhere baby, that's where I'm at...
Re: What a way to start off the year!
"Better to remain silent and be thought a fool than to speak and remove all doubt"Weiß-sechs wrote: ↑Tue Jan 08, 2019 5:07 pmBit random...
7 months as a forum member and that's your first post?![]()
- Weiß-sechs
- 5th Gear
His second post wasn't a bad one either...95ninety wrote: ↑Tue Jan 08, 2019 5:51 pm"Better to remain silent and be thought a fool than to speak and remove all doubt"Weiß-sechs wrote: ↑Tue Jan 08, 2019 5:07 pmBit random...
Well, yesterday my tuner and I tried to turn up the boost with a base map of 16psi and the car didnt take to it too well. Over boosted to 21psi across the board and that was after the throttle went back to 50%!.
Going to have a look at the N75 and if not that then its suspected to be the wastegate lines. Will do a few more logs in the meantime.
The valve covers are leaking excessively, and the little coolant line inside the oil cooler is leaking aswell. That will be a job in the next few weeks I suspect.
Transmission clunks when hot so maybe it's a sign of it started to go. Fluid and filter changed 4000 miles ago... maybe I'll save everything and yank the engine and tranny out together for a general overhaul of both. Time will tell.
Other than that she's just going to stay inside as the Northeastern Winter passes. No reason to have it succumb to salt and rust when it hasn't seen any jets entire life.
Guess I'll start making updates about the car. Love everything about it minus the maintenance lol
https://youtu.be/A9WVAilQaTE
Subscribed to your channel ! Look forward to seeing more
I'm taking a look at an A6 2.7t 6sp on Saturday. If it's in good shape I'll buy it for possible manual swap. Never seen on of these documented so "first" maybe,
Maybe.....
Maybe.....
Thanks for sharing your journey - looking forward to seeing more.
2004 Audi RS6 Avant Plus #283
Re: 2003 RS6 Build thread
Well, I just figured that since nobody else tends to share their experience with these cars, I might try and fill the void! Not the best working with a camera, but we'll get there. New video is up. Over the next few months, I will be performing the following:
-Timing Belt DIY
-Cam Chain Tensioner Removal / Gasket
-Bufkin Pipe Replacement
-And oh yeah, 6SP swap DIY (Well, I'll try and document as much as I can).
Also, I changed the title respectfully, because now... this IS turning into a bit of a build
https://www.youtube.com/watch?v=uoXj9TB1Iks
-Timing Belt DIY
I will be watching the gearbox manual swap closely... if you document that it would be fantastic, who doesn’t want a manual Rs6
https://youtu.be/q_FlzOovIOA
Me.
Haha, I don't want to really do it either, but I would rather spend $3000 and get rid of the issue once and for all rather than rebuild it for $5000+ when the time comes and hope it doesn't happen again.
The donner with 131,xxx on the odometer. Seen better days lol
20190217_110313 by Joel Francisco
20190217_110000 by Joel FranciscoWho is online
Users browsing this forum: No registered users and 319 guests
