Noooo!!.. It's started. Need to replace Cat
Maximo
Re: Noooo!!.. It's started. Need to replace Cat
Post by Maximo » Mon Jul 07, 2014 8:11 am
As for 17981.. What mount is it referring to?
This is an engine mount, add it to the list for MRC to sort out for you.
jangol
Post by jangol » Mon Jul 07, 2014 8:19 am
Thanks I can sort that myself.. Once I know what it is.. I didn't realise engine mounts are monitored via error messages.. I'll check wiring 1st to see if it's been damaged or something.. Reset warning & if it comes on again I'll replace it :£
Maximo
Post by Maximo » Mon Jul 07, 2014 11:21 am
This may help explain a little more. Looks like they cost cira £200 each and then you'll need to add on the labour. Make sure you get a scan completed once you've done the work as not all fault codes reset once the problem has be resolved.
http://forum.rs246.com/viewtopic.php?t= ... ount+boost
jangol
Post by jangol » Mon Jul 07, 2014 12:37 pm
Thanks... Is this only a main dealer part?
jangol
Post by jangol » Mon Jul 07, 2014 5:57 pm
Found this on the net.. Is this the right part..
http://www.europaparts.com/motor-mount-4b3199379j.html
jangol
Post by jangol » Mon Jul 07, 2014 5:58 pm
One of my guys attempted to swap the car out earlier but he's saying he can get to 2 of the nuts on the engine but not the top 2... Anybody got any expense of changing the part the thread is about. Have you got to start dropping the engine to get to it... To take off... Cheers in advance
jangol
Post by jangol » Mon Jul 07, 2014 5:59 pm
One of my guys attempted to swap the cat out earlier but he's saying he can get to 2 of the nuts on the engine but not the top 2... Anybody got any experience of changing the part the thread is about. Have you got to start dropping the engine to get to it... To take off... Cheers in advance
pete62
Post by pete62 » Mon Jul 07, 2014 6:23 pm
Picking up on the comments made earlier regarding de catting the exhaust.
I had to take a works vehicle for an MOT today at the local authority testing centre.Whilst there I asked about the de cat issue, the tester told me that until recently the only thing that mattered was whether you passed the emissions test. However he said that VOSA had recently sent out an amendment stating that if the tester believes that the original vehicle as supplied by the manufacturer would have been fitted with a cat then if the cat is missing it is an automatic fail.
In short it depends on how sharp eyed the tester is or of course if you know the right people......
Daveperc
Post by Daveperc » Mon Jul 07, 2014 8:52 pm
Jangol
I think MRC/Unit 20 have a fancy tool or similar specially to get at the two nuts - try giving them a ring in the morning.
Dave
jangol
Post by jangol » Wed Jul 09, 2014 12:42 pm
Hi,
Rang them yesterday, they didn't mention anything about a special tool.. all they spoke about was having to remove the subframe to get at the pipe?
jangol
Post by jangol » Wed Jul 09, 2014 12:43 pm
jangol wrote:Found this on the net.. Is this the right part..
Guys,
Can anyone confirm before I take the plunge
rossi46
Post by rossi46 » Wed Jul 09, 2014 12:54 pm
Give your local TPS a call for a price - most will deal with the public
amanda1
Post by amanda1 » Wed Jul 09, 2014 1:14 pm
rossi46 wrote:Give your local TPS a call for a price - most will deal with the public
+1would rather trust tps rather than euro parts any day ;)
950 nm torque!
Nobby
Post by Nobby » Wed Jul 09, 2014 1:57 pm
jangol wrote:Hi,
Thats what they had to do with mine. Believe there are 3 nuts for the downpipe. Around 3+ hours labour depending if they are seized and need replacing too. I think they basically tilt the subframe down at the back so the whole gearbox and subframe lowers a tad (which also need re-aligning to get back in the correct place)
Daytona RS6 Avant
yorkrs6+
Post by yorkrs6+ » Wed Jul 09, 2014 11:20 pm
Like I said not to late to bail..
If Grizz says subframe to get to the bolt your after, then there's a reason for it.
Engine mounts are just as bad from recollection.
A lot of labour their
Not for the faint hearted. Personally would rather not do any kind of repair like that, and would avoid a car where it was a do it yourself repair. getting a repair done by those mechanics like Grizz / MRC will ensure everything is done properly and they will tell you what else to do whilst there Stripping it down.
That's why you need deep pockets!
Users browsing this forum: Google Adsense [Bot] and 186 guests
