Post
by bilko1 » Fri Jan 17, 2014 7:39 pm
Have you got a Milltek exhaust system fitted? if so the heat from these causes a little flap to stick behind the heatshield which then lets water up through the aircon drain. Remove glovebox and kick panel and the plastic side trim along the door step. You can then lift the carpet up enough to check the air con drain and convenience box. If you want more room take the seat out.
