Doors locking after 10mph
rs6mick
Post by rs6mick » Thu Dec 08, 2011 5:06 pm
Hi people need help with Vagcom I have been told that I can set my doors to lock after the car hits 10mph just needed a guide on how to do this on my Vagcom I would be very great full for any help thanks
Maximo
Re: Doors locking after 10mph
Post by Maximo » Thu Dec 08, 2011 5:42 pm
I'll post my coding when I get home. Unless someone else beats me to it that is.
R18 GTX Estate > Saphire 2.0i Ghia > R19 16v > Vectra V6 SRi > M3 > RS6 Avant
Post by Shoppinit » Thu Dec 08, 2011 6:01 pm
Whatever your coding is, you need to add 32 to it.
However, if there is any fault with your central locking the the autolocking won't activate.
Also, it'll probably stop working after a few weeks on its own, anyway; This, even though no DTC is logged. If you clear the DTCs (even though there are none) then it'll start working again.
So before changing your coding, make sure that you have no DTCs and that you have cleared them even if there are none. This to make sure that your unit isn't already coded for it, but it's just not working.
Then you can add 32 to your coding. But make a note of the original coding, just in case.
Maximo
Post by Maximo » Thu Dec 08, 2011 10:15 pm
Just been and checked my coding. My module is 4b0 962 258 N, although I doubt that's to relevant. Anyway mine is; 05887. For me this works well, boot locks as you pull away and then the door(s) lock. I'm also using selective locking or more like unlocking, a single blip and the drivers door unlocks. A double blip and the rest open.
I hope that helps.
Garry
rs6mick
Post by rs6mick » Thu Dec 08, 2011 10:51 pm
Hi maximo me being all new to this Vagcom could you please explain how I do it start to finish I know I go into select control module then would it be central locking thanks for all your help
Mr Footlong
Post by Mr Footlong » Fri Dec 09, 2011 11:33 am
http://forum.rs246.com/viewtopic.php?f= ... =auto+lock
Not taking any responsibility for that link.
Current:
Gone:
rs6mick
Post by rs6mick » Sat Dec 10, 2011 2:52 pm
Hi people all done used the code maximo give me (thanks maximo) I think I defo need some traing on this Vagcom
Users browsing this forum: No registered users and 179 guests
