Sat nav in DIS
Sat nav in DIS
Can anyone suggest why the sat nav info will not display in the DIS on my Plus?
Thanks,
Jon
Thanks,
Jon
RE: Sat nav in DIS
Your TCM/Canbus module may be dead. Do your steering wheel buttons work? What about the menu button by the handbrake?
RE: Sat nav in DIS
do the sat nav buttons on the unit light up when you switch your lights on
RE: Sat nav in DIS
Can you rub your tummy and pat your head at the same time?
RE: Sat nav in DIS
have you tried toggling the display. the button at the base of the RH stalk toggles between computer, nav and no-display.
from memory, the default from startup is to display the nav info...
c5 RS6 plus in silver
Re: RE: Sat nav in DIS
Thanks for the replies.
No buttons on wheel. Menu button works fine.Your TCM/Canbus module may be dead. Do your steering wheel buttons work? What about the menu button by the handbrake?
Yes; will that help?Can you rub your tummy and pat your head at the same time?
Not sure which lights you mean?do the sat nav buttons on the unit light up when you switch your lights on
Yes, just toggles between comp and no-display.have you tried toggling the display. the button at the base of the RH stalk toggles between computer, nav and no-display.
RE: Re: RE: Sat nav in DIS
I presume you've actually programmed a destination in?
Is it RNS-D or E?
RNS-E and, yes, with destination set!
Is it a retrofit? Can't remember if all plusses had E. Have you got a vagcom?
Have you got the security code for the radio? You could try a reset. You could disconnect the battery for a few minutes and reconnect it. This is recommended for suspected trouble with the TMC/Canbus module.
Standard on plus.
No vagcom.
Will have code somewhere so I will have to root it out and try the reset.
No vagcom.
What he means is that when you put your lights on, all the buttons on the dash light up red. This should include all the buttons on the RNS-E too, which it does by responding to a message on the canbus. If the canbus is faulty to/from the RNS-E (so that messages don't get to the DIS), then the message to turn the lights on may well not get through too. I guess that's what he's thinking.JonW wrote:Not sure which lights you mean?do the sat nav buttons on the unit light up when you switch your lights on
I see; yes, all the buttons on the unit and dash come on.andyt wrote:What he means is that when you put your lights on, all the buttons on the dash light up red. This should include all the buttons on the RNS-E too, which it does by responding to a message on the canbus. If the canbus is faulty to/from the RNS-E (so that messages don't get to the DIS), then the message to turn the lights on may well not get through too. I guess that's what he's thinking.JonW wrote:Not sure which lights you mean?do the sat nav buttons on the unit light up when you switch your lights on
Users browsing this forum: Majestic-12 [Bot] and 515 guests
