Tips on replacing o/s front cv boot
allblack
Post by allblack » Tue Aug 07, 2007 6:01 pm
Has anyone changed these on the RS6?
My outside front cv boot is split and I have purchased a replacement. I had a quick look today and not sure of the right way to get at the drive shaft and if I need any special ball joint separator tools?
grizz
RE: Tips on replacing o/s front cv boot
Post by grizz » Tue Aug 07, 2007 7:24 pm
pm sent .
Unit 20
0151 3366888
allblack
Post by allblack » Tue Aug 07, 2007 9:09 pm
thanks Grizz - you've saved the day (again!)
skiwi
Post by skiwi » Thu Aug 09, 2007 8:06 pm
generally whould have to be replaced. a ripped boot is pretty common and replacing the boot and repacking with grease is all that is required. generally the cv shouldn't be replaced unless it is noisy,,,
marmite
Re: RE: Tips on replacing o/s front cv boot
Post by marmite » Mon Aug 13, 2007 9:47 pm
skiwi wrote:generally whould have to be replaced. a ripped boot is pretty common and replacing the boot and repacking with grease is all that is required. generally the cv shouldn't be replaced unless it is noisy,,,
Hence the title 'Tips on replacing o/s front cv boot'
03 RS6 Saloon Daytona Grey | Milltek | RS6+ Wheels | RS6 Mats | Tesco Club Card Points
skiwi
RE: Re: RE: Tips on replacing o/s front cv boot
Post by skiwi » Wed Aug 15, 2007 12:13 pm
marmite, you are clearly a very attentive person if a little irony challenged - either that you are one of life's natural policemen....
but you did make me re-read the original request.....
tips:
1) you can get away with re-using the (old) axle bolt to remove the cv from the axle, it will tighten down and pull the joint off, but if no luck with that method, a 2-arm puller will do in place of the special tool...
2) don't displace the balls, and make sure to clean all the old grease out. use a citrus solvent and rinse with water and thoroughly dry.
3) don't be afraid to us a bfh to get it all back on the shaft - albeit with a wooden buffer....
4) instead of the proper circlip pliers you can use a pair of straight cutters.
5) don't circlip the small end until you have re-assembled to allow time to get the air out of the boot...
Users browsing this forum: No registered users and 154 guests
