Is there a point under the bonnet of my RS6+ were I can easily connect to that will supply 12v (less than 1 amp) when the ignition is on? i can find this in the fuse box in the car of course but then need a route into the engine bay. Any help appreciated.
MartynC
Ignition derived 12v supply
RE: Ignition derived 12v supply
Under/behind the drivers kick plate you will find some metal bars, the one marked 75 is a switched live.
Blue_Thunder
- Top Gear
tartan_rob
Re: RE: Ignition derived 12v supply
Help .. is this also available in the C6 RS6 ? and forgive my ignorance .. whats a Drivers kick plate?craigyb wrote:Under/behind the drivers kick plate you will find some metal bars, the one marked 75 is a switched live.
