Nearside Xenon lower than right
oliew
Post by oliew » Wed Sep 27, 2006 12:21 pm
Hi,
ive searched the forums for this and only found 1 problem the same but no conclusion was found in the posts.
my nearside xenon is lower than the other one sometimes , if i run the up/down adjusting through VAG they go to the same height, then it auto adjusts back down after i come out of vag, also no error codes are reported in the xenons module.
If i adjust with screwdriver then surely if the nearside goes back ok (which it does do) it will be aimed right up high, so is my sensor playing up on the roll bar? what can i do to fix this?
thanks in advance
Oli
S4 B5 - MRC
MarkB
RE: Nearside Xenon lower than right
Post by MarkB » Wed Sep 27, 2006 12:29 pm
You only have one sensor in the front and one in the rear so I would look first at the servo on the offending light
Mark
oliew
Post by oliew » Wed Sep 27, 2006 12:51 pm
right, so if there is not a sensor for each side of the car it must be something just for that light, where is the servo for the light?
S4 B5 - MRC
MarkB
Post by MarkB » Wed Sep 27, 2006 12:52 pm
No idea sorry
Mark
MarkB
Post by MarkB » Wed Sep 27, 2006 1:09 pm
I found this...
Range control
Range control.jpg (54.77 KiB) Viewed 540 times
Mark
MarkB
Post by MarkB » Wed Sep 27, 2006 1:10 pm
It's for an RS4 but just did it so quickest way to find a xenon installation. I can email you the full size .jpg if you like...
Mark
Return to “Electrical”
Users browsing this forum: Google Adsense [Bot] and 47 guests
