Blue engine light when you turn on vehicle
New RS4 owner here. Obviously the blue engine symbol indicates the engine is still cold… once the light goes off does it mean the engine is warm enough for aggressive acceleration? Or do you need to wait longer until engine temperature hits 70-90degrees?
Re: Blue engine light when you turn on vehicle
Personally I tend to look at the oil temperature not the water. I usually wait until the oil is up at 100 degrees before giving any real hard acceleration. (B8 RS4, but shouldn't make any difference)
Congrats on the new car, enjoy
Sent from my Pixel 5 using Tapatalk
Where is this blue engine light? Any pics, pls.
2022 RS4 - Turbo Blue / Black
Gone: 2018 RS4 - Navarra Blue / Black, 2016 A6 BiTDI - Midnight Blue / Black, 2016 Golf GTD with a "lot" of toys, 2016 M3 CP - Mineral Grey / Black, 2009 135i - Le Mans Blue / Black
Thanksnoidea wrote: ↑Tue Sep 28, 2021 4:35 pmPersonally I tend to look at the oil temperature not the water. I usually wait until the oil is up at 100 degrees before giving any real hard acceleration. (B8 RS4, but shouldn't make any difference)
Possible change on the very latest cars? photo seems to be a Sept 2021 car (My 2018 car doesn't have any blue light)
I think oil temp is more important (as has been said).
Gone : 2017 M3 CP
Gone : 2007 B7 RS4 (
Gone : 2017 M3 CP
Will upload a pic of it shortly, cant find one anywhere online. I figured it was referring to oil temp (not water). It turns off after about 5 mins of driving.
Same her albeit oil temp to 80 degs for me.
TX.
TX.
Coming from a long line of BMWs, I like the fact you can see the water and oil temps.
This is the light im referring too
Ah, OK, thank you.
- partymonkey
Pre facelift B9 owner here, so no blue light.
Out of curiosity, for the OP.. at roughly what oil temp have you noticed the blue light go off? Would be interested to see what point Audi thinks that the oil temp is sufficient.
Like others have said.. I tend to wait until oil temp is at least 80 deg before being 'more enthusiastic' but my oil temp typically doesn't register anything on the gauge until around 60 deg.
Jon - RS4 B9
The light goes off after around 5mins of light driving. So I'd say around 10deg. However i'm not sure whether that actually indicates the oil temp is sufficient to drive without precaution. 10 deg seems very low... but maybe the engine is designed to operate fully at low oil temp. if not, then the light is quite misleading.partymonkey wrote: ↑Thu Sep 30, 2021 9:48 amPre facelift B9 owner here, so no blue light.
If anyone knows what the light officially indicates id love to know....
- partymonkey
^^ Cheers... I guess it would probably say something about it in the warning lights section of the manual? No reference to the light in mine but wasn't expecting there to be.
Congrats on the car btw!
Jon - RS4 B9
- 1st Gear
My 2020 rs4 doesn't have this light in the manual. On the my audi app under literature, which manual do you have?
