Wider track advantage?
dace
Re: RE: Re: RE: Wider track advantage?
Post by dace » Mon Nov 05, 2007 4:13 pm
Ads4 wrote:Was that the same tyre type though? I ran 235/35/19s but get much better grip on my thinner 225/40/18s, because the 19s were Kuhmos and crap and the 18s are pirelis :wink:
Fair point. No the tyres were different, however I find both GSD3's and PS2's very similar in terms of dry weather grip.
Both are excellent. I still maintain that the 265 width gives better stability.
Just my 2p worth
MarkB
Post by MarkB » Mon Nov 05, 2007 4:17 pm
dace wrote:I still maintain that the 265 width gives better stability.
You say that but there's more to it than just the 265, you went up from 18's to 19's also. 30 sidewall rather than 35
Mark
dace
Post by dace » Mon Nov 05, 2007 4:47 pm
Therefore rolling circumference remains the same?
MarkB
RE: Re: RE: Re: RE: Wider track advantage?
Post by MarkB » Mon Nov 05, 2007 7:29 pm
but the sidewall stiffness changes with the lower profile tyre. This will improve turn-in
Mark
dace
Post by dace » Mon Nov 05, 2007 7:42 pm
That may be it then Mark.
I intended to use my 18" oem's for track days, however the 19's are so good I use them all the time.
Oem's are stored away for now!
MarkB
Post by MarkB » Mon Nov 05, 2007 7:45 pm
some track tyres on the OEM's would be cool
Mark
dace
Post by dace » Mon Nov 05, 2007 7:48 pm
Yes I tried some Dunlop SSR semi track tyres and found them to be worse than my GSD3's!?
Only used them once and now they are sat around....
MarkB
Re: RE: Re: RE: Re: RE: Wider track advantage?
Post by MarkB » Mon Nov 05, 2007 7:49 pm
dace wrote:Yes I tried some Dunlop SSR semi track tyres and found them to be worse than my GSD3's!?
Oh, I'll keep quite then. :oops:
Mark
Peakz
RE: Re: RE: Re: RE: Re: RE: Wider track advantage?
Post by Peakz » Mon Nov 05, 2007 8:00 pm
Dave - how old were the SSR's or rather how long had they been laid-up prior to using them on track?
EVO's tyre test made a point of newer tyres giving better grip than ones that had been in storage for longer than a few months.
dace
Re: RE: Re: RE: Re: RE: Re: RE: Wider track advantage?
Post by dace » Mon Nov 05, 2007 8:04 pm
Peakz wrote:Dave - how old were the SSR's or rather how long had they been laid-up prior to using them on track?
Good point. I read the very same article.
Don't really know, however I bought them from Camskill and they were cheap! After reading that said article I looked on the tyre, however no clues to when they were manufactured.
Peakz
RE: Re: RE: Re: RE: Re: RE: Re: RE: Wider track advantage?
Post by Peakz » Mon Nov 05, 2007 8:14 pm
DOT marking - first two digits denote week of the year, last two digits are the year of manufacture.
Perhaps these tyres don't regular markings though . . ?
dace
Post by dace » Tue Nov 06, 2007 1:43 pm
Thanks Paz. Dot marking is 3806.
