Exhaust manifold porting
s4woody
re
Post by s4woody » Thu Jan 17, 2008 4:52 pm
just look at this pic to see what i meant when i said face of manifold..
it is not a difficult job to do and certaintly not worth paying someone to do..surely if your going to go to all the trouble modifiying your car you would atleast wanna put something into it yourself..other than opening your wallet..
otherwise hand over your car and credit card and say call me when its done..or you've hit the card limit..
GARTH ROAD MOT CENTRE LTD
020 83353032
s4woody
RE: Re: RE: Re: Exhaust manifold porting
Post by s4woody » Thu Jan 17, 2008 4:55 pm
ive seen these manifolds recently and how many have gone wrong..more than the OEM manifolds that develop a rattle..or just word of mouth..anybody on here fitted them and had a bad experience..other than MRC..that is..
with so many problems noted on the ebay manifolds
020 83353032
quattronutter
Re: re
Post by quattronutter » Sat Jan 19, 2008 12:08 am
s4woody wrote:just look at this pic to see what i meant when i said face of manifold..
thats my manifold!the welds protrude about 3-4 mm at certain points,obviously it wont make a huge difference removing them,they will cause more turulence than anything,if they are opened out to the same size as the head there will be marginally better flow,worth doing if your doing other bits too,ie turbos
Doug_S2
Trader (Expired)
RE: Re: re
Post by Doug_S2 » Sun Jan 20, 2008 9:53 pm
you are not taking extra material off any runners - you are just getting rid of the lip on the exhaust manifold where it has a big mig weld. on hte collectors side you just smooth out the lip on the cast curve.
Never hada problem with any of the ported ones - but they are all done on the later design of manifolds with cast ends.
http://www.MRCtuning.com
MarkB
RE: Re: re
Post by MarkB » Mon Jan 21, 2008 3:35 pm
What sort of improvement in torque and max power would you expect to see on a stage3 S4 running 200cpi cats?
Mark
quattronutter
Post by quattronutter » Fri Jan 25, 2008 8:44 pm
better pic of manifold
MarkB
Post by MarkB » Fri Jan 25, 2008 9:33 pm
quattronutter wrote:better pic of manifold
Have you tig'd that at all or is it just ground away?
Mark
quattronutter
Post by quattronutter » Fri Jan 25, 2008 9:40 pm
tig,d and ground down, just as strong as it was originally,much better..
MarkB
Post by MarkB » Fri Jan 25, 2008 9:42 pm
It does look so much better. I think it's going to have to be on my must do list. More COST!
Have you also skimmed the manifold or is it the gasket I can see in the first picture?
Mark
quattronutter
Post by quattronutter » Fri Jan 25, 2008 9:48 pm
gasket in the first pic,manifold has been skimmed ye..
Users browsing this forum: No registered users and 44 guests
