Caution: hi temp!
2.2 I5 20v turbo - 315 bhp
timucin
Caution: hi temp!
Post by timucin » Sun Nov 30, 2003 7:41 pm
red hi temp signal at the gauges but temp is 70-80 celcius on analog and oil temp is low. what can be wrong?
Quattro
timucin
Re: Caution: hi temp!
Post by timucin » Sun Nov 30, 2003 9:44 pm
any ideas?
Quattro
timucin
Post by timucin » Sun Nov 30, 2003 9:45 pm
it be-beeps all the time man, iam about to loose my nerve system,everything is cool why does it make this?
Quattro
markhalligan
Post by markhalligan » Mon Dec 01, 2003 12:04 am
Timucin,
if the engine is not really getting hot try disconnecting/changing the multi function temp sensor. This is on the coolant manifold (3 pin plug, I think) under the inlet manifold, when this malfuntions it can also reduce performance, as happened to someone else recently, here:
http://www.s2forum.com/forum/showthread ... eadid=1220
Mark.
1993 ABY Coupe
Turbonetics Garret/KKK hybrid BB turbo , MTM sport quattro exhaust manifold, Custom fabricated 3" downpipe, seperate wastegate exhaust pipe, Decat, RS2 inlet manifold, RS2 intercooler, RS2 injectors, 5bar-200lt/hr fuel pump, 5bar fuel regulator, Modified crankcase ventilation, 393.4 bhp @ 6798rpm, 356.2lbft (470.19NM) @ 4938rpm at 1.8 bar max boost pressure, mapped 'on the fly' at 28 deg C max ambient temp(hot day) by Mihnea.
18inch BBS RK II split rims,225/40 SO3's, 322mm front rotors with Brembo calipers, 280mm rear rotors with S8 calipers/carriers, Boost/EGT gauge. Whiteline rear anti-roll bar.
timucin
Post by timucin » Mon Dec 01, 2003 9:20 pm
sorry i am idiot!
only fault was missing water
[img]images/graemlins/rocketwhore.gif[/img]
Quattro
timucin
Post by timucin » Mon Dec 01, 2003 10:29 pm
after facing some serious problems i thought its something complicated , LOL
Quattro
robo
Post by robo » Tue Dec 02, 2003 9:18 pm
just cant get enough of it
timucin
Post by timucin » Wed Dec 03, 2003 12:35 am
[img]images/graemlins/grin.gif[/img] [img]images/graemlins/grin.gif[/img]
actually i add water yesterday and it was lighting again this morning. i think there is a serious leak from somewhere,hope something easy like untighten clamp etc...
didnt have any time today and wont haver tommorow but will take it to service soon..
Quattro
timucin
Post by timucin » Wed Dec 03, 2003 11:14 pm
the plastic top of radiator is broken by somehow, i just bought it like two motnhs ago!!!
new radiator but broken top ( crack )
[img]images/graemlins/24430-audibash.gif[/img]
Quattro
Cobstar
Post by Cobstar » Thu Dec 04, 2003 9:15 am
I had a new radiator fitted to mine earlier this year, which developed a leak a few months later due to a manufacturing fault. It was repaired under warranty and I was told the repair means it's better than it was when new.
timucin
Post by timucin » Thu Dec 04, 2003 10:56 am
cobstar; we dont have good services here , they dont care about guarantee etc. this radiator was invoiced at 08-november-2003 TO ME, i have the invoice in front of me right now....
damn... its not a cheap part... but i have to buy another one.
Quattro
PhilT
RS246.com
Post by PhilT » Sun Dec 07, 2003 11:07 am
You can get replacement rads with metal ends.
timucin
Post by timucin » Sun Dec 07, 2003 2:43 pm
fixed it with sun-fix
where can i get metal ends? from audi?
thnx for help
[img]images/graemlins/smile.gif[/img]
Quattro
Doug_RS2
Post by Doug_RS2 » Sun Dec 07, 2003 4:43 pm
You can replace the main radiator with type 85 Coupe quattro metal radiator - this will also mean you can get rid of the auxiliary radiator.
In our climate we can get away without changing our main radiator and get rid of the auxiliary radiator - but remember to block the two hoses to the aux radiator as this is in parallel to the main radiator - connecting them together will bypass the main radiator - not good.
HTH
Users browsing this forum: No registered users and 23 guests
