Oil
Oil
A whole new can of worms for you.
Carrying on the car's Audi service history, I had it serviced and MoT'd at Audi Newbury. And I forgot to specify the oil. The previous owner had Listers (Audi Coventry) service it for years and they used a semi synthetic.
Audi Newbury used VW group's Quantum. There's no mention of synthetic, but the spec is very high and lists on the container all the likely cars you can use it in.
Under intense questioning the mechanic said it's what they use for the high powered cars unless told to do something different.
Anyway, it performs fine but whereas the previous owner said it used very little oil and didn't require any between services, I'm up to a litre every 3,000 miles. Not bad for a 135K car, but considerably higher than with the semi-synthetic.
Any thoughts?
Dicky C
(The car's previous owner, Neil Lefley, is an interesting chap, look him up on the internet. If you don't go straight to him, try adding Trident, Muira or 365 GTC to your search criteria)
Any thoughts?
Dicky C
RE: Oil
Many discussion on the best oil for the RS2 on many Forums over Europe...
They all summed up that Castrol RS 10/60 it's the best allover.
Personally i use that every oil change since 1997 on my RS2 and i'm still happy with it.
Don't go on too fluid oils like Mobil 1 0/40 or similar values because they're good for more modern motors not for our IL 5 cylinders you'll end up having higher oil consumption.
Stefano
Stefano
scillyisles
hey guys i know this post was a long time ago but i also use Mobil 1 0W/40 fully synthetic and i dont have any oil consumption issues my car has had it in for about 5yrs
i also have it in a highly tuned mk2 golf and other than a slight oil leak now and again it also runs fine!
I really consider this the best oil money can buy
When i was in Greece i used castrol 10W60.No problems.However here in the UK with the low temps, i noticed that the car kind of struggled when cold and also took quite a while to actually get a bit warmer.So i tried on my recent oil chance the Silkolene 10W50 and i can say that for these temps,this oil is much better.The car is more lively now and the normal operating temps are more easily reached.
I had about 300ml consumption with the castrol on a 30.000Kms engine(rebuilt) @ 7500Kms.I will note what the consumption will be with this one,but i dont really expect any big difference
www.opieoils.co.uk
Forum discount available with these guy's.
Oilman from above business posts on S2 forum. Plenty of info on correct oils to use.
Silkolene Pro S 10W50 ester synthetic is his recommendation for RS2.
Doug from MRC say's Quantum Synta Gold is fine as long as the car is not thrashed or tracked.
rs2315.
rs2315.
