rs2 brakes and turbo problems
2.2 I5 20v turbo - 315 bhp
stu_sclater
Post by stu_sclater » Fri Oct 28, 2005 4:46 pm
Hi,I've just imported a mint(or so i thought)black rs2 full leather and 70k miles on the clock.The problem is the disc's feel as though they are warped,anyone know where i can get some new ones with out costing me to much.And also there seems to be a problem with the turbo,the boost does not start building till 3500 and only really gets going at about 5000,any ideas on these problems would be greatly apprieciated.Other than that the cars great.Cheers for your help........
robo
RE: rs2 brakes and turbo problems
Post by robo » Fri Oct 28, 2005 5:53 pm
You can get cheap discs from here if your car has standard brakes.
http://www.eurocarparts.com/
just cant get enough of it
AAH!
Re: rs2 brakes and turbo problems
Post by AAH! » Fri Oct 28, 2005 8:02 pm
You may have a boost leak or you may have a bigger non-original turbo that spools up later.
Do a search for boost leaks on this forum and on www.s2forum.com
Getting brake parts from Porsche or a discount Porsche parts shop such as www.type-911.co.uk or www.design911.co.uk are often cheaper than Audi.
Have a look at this previously posted list of Porsche brake parts that are used (in theory) on a RS2. I did not compile this list so cannot guarantee its accuracy.
Angus
Possible Porsche brake parts for RS2.zip
(10.89 KiB) Downloaded 94 times
RS2 +
DavidT
RE: Re: rs2 brakes and turbo problems
Post by DavidT » Fri Oct 28, 2005 8:39 pm
That attachment contains a virus called W97M.Thus.gen according to Norton AntiVirus
AAH!
Re: RE: Re: rs2 brakes and turbo problems
Post by AAH! » Fri Oct 28, 2005 9:26 pm
DavidT wrote:That attachment contains a virus called W97M.Thus.gen according to Norton AntiVirus
How horrible. Sorry about that, don't know how that happened. I made the zip file from a MS word document as this site wouldn't let me attach a word doc.
I cant seem to delete the attached file.
Try here instead:
http://www.s2forum.com/forum/showthread.php?t=9177
Sorry.... Angus
RS2 +
DavidT
RE: Re: RE: Re: rs2 brakes and turbo problems
Post by DavidT » Fri Oct 28, 2005 11:07 pm
No worries mate.
I know you didn't do it on purpose but I didn't want you to pass it on either.
David
VaudiGR
Post by VaudiGR » Sat Oct 29, 2005 6:58 am
on the turbo issue...i can understand that the turbo starts to kick in on 3000rpm,but then it only kicks in at 22psi around 3700rpm.If it gradually goes up could this mean that i need a turbo service?
i am going to have one with my timing belt change in about 10000km but i was just wondering from the syptoms....
in general are there any symptoms of a turbo service requirement?
stu_sclater
Post by stu_sclater » Sat Oct 29, 2005 8:07 am
Thanks for your help guys,I'll try the links you suggested.Cheers.....
PhilT
RS246.com
Post by PhilT » Wed Jan 25, 2006 9:49 am
The file has been cleaned.
If you have downloaded it and are unsure that your machine is clean, then try this http://www3.ca.com/securityadvisor/virusinfo/scan.aspx
Hansen
Post by Hansen » Fri Mar 31, 2006 8:58 pm
I had the same problems with my brakes. New discs and "homefixed" calipers.With Porsche logo... The result was not so bad:)
Hansen
Post by Hansen » Fri Mar 31, 2006 8:59 pm
calipers in the kitchen..
Return to “RS2 (B4) 1994-1995”
