remote opening - keys
matcook2005
anyone suffering key forgetting car syndrome
after about half a day my key stops talking to the car, i re train it and then it forgets the next day
solutions?
solutions?
- shineydave
RE: remote opening - keys
Battery on it's last legs maybe?
What do you mean you re-train it?
matcook2005
bloody key
changed batteries
retrain means if you put the key in the drivers door and hold it open the car resends the info to the key. thus it works but mine seems to have alzheimers
ta
ta
RE: bloody key
I dropped mine in a bucket of water without any memory loss! Very carefully dried it out and still all seems well. Couldn't believe my luck. But I will remember the tip in case I have problems. Is that a process you need to go through when changing batteries in the remote?
...Paul.
...Paul.
- harry
RE: bloody key
No you have to take all keys including the skeleton to the dealer so they can reprogramme the lot on a computer thingy?Is that a process you need to go through when changing batteries in the remote?
Wait a minute - is that Vag Com by any chance?
Practise safe sex & drive a hybrid if you can...
RE: bloody key
I thought the procedure for retraining a key was as described above - this should include changing batteries?No you have to take all keys including the skeleton to the dealer so they can reprogramme the lot on a computer thingy?
- harry
RE: bloody key
Am led to believe that if you change the battery on one then the others cant communicate with it/the car therefore have to all be reprogrammed. No mention of the door retraining thing from the dealer.
Or id thid just another money making exercise from them???
RE: bloody key
This may help .... http://forums.audiworld.com/s4/msgs/2067421.phtml
RE: bloody key
keys programming is quite complicated and has to be done by the dealer, it involves a process which needs the dealer to contact Germany with chassis number to obtain access codes........ long drawn out and and expensive...............
- shineydave
Re: RE: bloody key
that's if you're adding a new key with a different transponder for the immobiliser. to reprogram just the remote part you can follow the procedure of putting the key in the door, unlocking it manually then holding down the unlock buttonsimple1 wrote:keys programming is quite complicated and has to be done by the dealer, it involves a process which needs the dealer to contact Germany with chassis number to obtain access codes........ long drawn out and and expensive...............
RE: Re: RE: bloody key
Shiney's right, I changed the battery on mine and followed this procedure. ...easy
I changed the batteries in both my keys (one key at a time) and all was well.
As for the original problem, perhaps VagCom would show a fault on the car somewhere?
Paul
Paul
Huge Grin
If you dont "do it now" you never will.
Huge Grin
- harry
so i've been ripped off then to the tune of twenty odd quid by - thats right you guessed it people - the stealershipto reprogram just the remote part you can follow the procedure of putting the key in the door, unlocking it manually then holding down the unlock button
- shineydave
it's a complicated procedure
1. insert key into door and turn to unlock
2. press unlock button on remote
3. undo clients trousers
4. administer severe rodgering in a manner which is illigal in 49 states
5. extract £20 from clients wallet
6. kiss the client (most people like to get kissed when they get f**ked)
