Secondary air pump and diverter valves. Testing.
2.7 V6 30v biturbo - 380 bhp
Jollyman
Post by Jollyman » Tue Oct 14, 2014 2:47 pm
Hi All
I'm new to the forum but would be grateful for any advice you may have.
I have a 2000 RS4 B5, and the engine management light is on because of the secondary air pump failure.
Although the pump was not 2 years old when I had the problem diagnosed Audi refused to replace it because they said the pump had failed as 1 or both diverter valves had failed causing moisture to enter the pump and therefore causing it to fail. I have since bought a second hand pump and valves and plan to swap them over. The question is how do I test to make sure both valves are working and avoid this happening again.
Many thanks
Tim
graemep
Re: Secondary air pump and diverter valves. Testing.
Post by graemep » Thu Oct 16, 2014 11:08 am
The best way to avoid any further issues would be to have the system removed, and coded out - speak to a reputable tuner rather than Audi to have this done
The secondary air system is only really there to control emissions on a cold start, and is not used when the car is up to temp.
