MAF-EGTs and spark plugs were changed by new ones....fuel trim and EGT fault codes were all been cleared. The vehicle seems to operate better than before as well as less fuel consumption. But we have a new problem.....when the engine is on boost about 5000rpm, It sometimes feels sluggish and cuts power suddenly....the car behaves like a NA 2.0 rather than 2.7T.
We took the car to the mechanic where the parts were installed and diagnosed it. Fault codes are right below. The car has decat.
16815/P0431/001073 - Warm Up Catalyst; Bank 2: Efficiency Below Threshold
17521/P1113 - Oxygen (Lambda) Sensor; B1 S1: Internal Resistance too High
I am not sure these faults are really effective on performance cut, the car has decatted as I mentioned.
This is the last fault code and most suspicious !!!!
17964/P1556 - Charge Pressure Control: Negative Deviation
As I searched for the fault code, I got some info from the net.
Possible Symptoms
Reduced power output
Limp mode
Possible Causes
Boost Pressure too Low
Hoses/Pipes incorrect connected, disconnected or leaking
Charger Pressure Control defective
VNT (variable nozzle turbo): nozzles stuck
Solenoid Valve for Boost Pressure Control (N75) defective
Possible Solutions
Check Hoses/Pipes to/between Components
Check Solenoid Valve for Boost Pressure Control (N75)
Check / Clean / Replace Charge Pressure Control
Check / Clean mechanism for variable nozzle
Has anyone faced with the same problem? What to look for initially? Leaks or N75?
Thanks for your help
