slight part throttle missfire
2.7 V6 30v biturbo - 380 bhp
missmouse
Post by missmouse » Tue Sep 15, 2009 11:07 pm
I sometimes get a slight missfire or hesitation when I accelerate off boost at part throttle between 3k & 4k revs.
Fitted new plugs.
The maf has been changed a couple of years ago (alledgedly!)
On full boot the car goes like f**K!
Also it doesnt do this all the time.
Any ideas? :?
beastman
Re: slight part throttle missfire
Post by beastman » Tue Sep 15, 2009 11:43 pm
missmouse wrote:I sometimes get a slight missfire or hesitation when I accelerate off boost at part throttle between 3k & 4k revs.
Fitted new plugs.
Any ideas? :?
Mine was doing this a while back and a new lambda sensor cured it although believe can be other causes.
Diesel, fuel of the devil!
missmouse
RE: Re: slight part throttle missfire
Post by missmouse » Tue Sep 15, 2009 11:59 pm
is there a way to check this using vagcom? Are there 2 lambda probes on the rs4?
RS4_fin
Post by RS4_fin » Wed Sep 16, 2009 8:31 am
For possible causes, use search function with "hesitation"... that is if not yet already done.
boxerdogted
Post by boxerdogted » Wed Sep 16, 2009 10:35 am
Four lambda's on RS4. Do a check with vagcom for fault codes first.
2001 RS4 Misano Red
missmouse
Post by missmouse » Wed Sep 16, 2009 10:08 pm
Im a bit of a newbie with vagcom guys, any chance of talking me thru the procedure to do these tests?
BTW Ive only got the free basic copy of vagcom, will that do this?
